C.A.R.B Cats Nowhere To Be Found
Anyone else in CA notice this? Every retailer I've checked with is out of stock for at least 4-5 weeks. I've checked Napa, O'Reilly, Autozone, Rock Auto, Advance, and even Honda dealerships. Luckily I have other cars I can drive to work but does anyone know what's going on? Did all of our cats die simultaneously? XD
*Edit - I found a dealer that can order one. FOR $2,100... |
You can try carbcats dot com it’s a database site that list all CARB approved cats. It’s not a retail site, but it lets you know if there is a manufacturer that makes a cat for your vehicle. |
the part you want is https://magnaflow.com/products?partNumber=546261
seems like there are plenty available... |
Just curious how anyone knows the catalytic converter is CARB compliant (or not) when it's shrouded by the OEM heatshield and the car passes all the smog tests.
https://cimg0.ibsrv.net/gimg/www.s2k...f9d272672b.jpg |
I'm fairly certain it's still compliant without the heatshield, I haven't had any issues.
There's a Berk high flow cat hiding inside that heat shield which you didn't see and was the point. I doubt it's CARB approved but how is anyone to know without disassembly if it passes the emissions testing?
-- Chuck |
Oh, well that works too but only if your HFC doesn't trigger the secondary O2 sensor and other monitors. I used to run a 63mm Berk with the OEM heatshield before switching to a Gernby exhaust and could never get the secondary O2 CEL to go away without disabling it in Flashpro, which would have lead to a failure come smog time.
It's definitely worth a shot, but not a guarantee. |
That's what $10 02 bung extenders are for.
Originally Posted by s2000Junky
(Post 24540256)
