C/R lip.. question
I want to get the C/R lip on Monday..
Will it drop the front alot more? I'm already really low in the front.. .5 finger in wheel gap
if it will lower it, ill just adjust the koni's and put on upper perch.
Thanks
Marc
Thanks
Marc
I believe w/ any lip it lowers the ground clearance in the front just not as much as w/ some aftermarket lips...I'd say a good .5 " to 1" but no more. Doesn't the C/R lip come w/ a flat black area on the lowest point of the lip w/ scraping thought in mind from the design point of view...like a safety barrier?!! You can't see it from a distance but when you walk up close to it you can see it clear as day as well as feeling more durable in that area compared to the rest of the lip?
Originally Posted by Rubn1out4GudLuk,Dec 14 2008, 10:42 AM
You can't see it from a distance but when you walk up close to it you can see it clear as day as well as feeling more durable in that area compared to the rest if the lip?
