Sponsored by: CARiD
Cannot screw on OEM Titanium shift knob AP2
Old Feb 17, 2010 | 12:18 PM
Alexnova's Avatar
Default Cannot screw on OEM Titanium shift knob AP2
Just got the OEM Ti knob from Handa accessories, however when I try screwing on the knob it doesn't work. It gets a little bit screwed on then stops. I tried to search on this forum for some help, but seems like everyone was able to get it installed. Do I need to apply some lubricant to apply the knob?
Old Feb 17, 2010 | 12:22 PM
Moddiction's Avatar
Former Sponsor
You might have started threading it on not with the thread pattern. If that is the case it probably got cross threaded now. Try moving it to a different start point to thread on. If that still doesn't work you might need to re tap it.
Old Feb 17, 2010 | 12:31 PM
Alexnova's Avatar
No luck trying a different starting point, still gets stuck in the same spot. What do you mean by re-tap it? Sorry I'm new to the lingo.
Old Feb 17, 2010 | 12:33 PM
Nickamsweet's Avatar
like create the threads again...
Old Feb 17, 2010 | 12:39 PM
Alexnova's Avatar
The threading within the knob looks fine, could it be the shifter itself? It had a junk aftermarket one (A Pilot Automotive one to be exact, which has a plastic piece which you force down onto the shifter) so I'm not sure if that could of damaged the threading on the shifter.
Old Feb 17, 2010 | 01:02 PM
Moddiction's Avatar
Former Sponsor
Not sure. Look at both threading carefully. I am sure the shift knob is made to fit as basically all Honda's use the same 10x1.50mm thread pattern.
Old Feb 17, 2010 | 05:13 PM
gospeedgo1's Avatar
did you get the one for your year? it looks like they have one for 2000-2003 and one for 2004-2009.
Titanium Shift Knob
Genuine Factory Honda S2000 titanium shift knob. Designed for the S2000 with a nod to Honda's great racing heritage. This shift knob provides a unique feel and distinctive appearance.
Reuses the stock retaining nut, if yours is missing see below to order one separately.
Fits Years 2004-2009, for other years <Click Here>
Old Feb 17, 2010 | 07:30 PM
TKim103's Avatar
my OEM Ti knob fit perfectly
Old Feb 17, 2010 | 09:21 PM
Moddiction's Avatar
Former Sponsor
All year s2k's have the same thread pattern.
Old Feb 17, 2010 | 11:01 PM
IHoP's Avatar
check the thread on the shifter for messed up threads or maybe some sort of dirt or something that could block the knob from screwing on.
If you want to check the threads of the knob the only thing I can think of is to bring the knob to a hardware store and test out a bolt that has the same thread pattern on the knob.
