Sponsored by: CARiD
Ceramic Coating exhaust pipe
Old Feb 11, 2015 | 05:52 PM
nizmo_max's Avatar
Default Ceramic Coating exhaust pipe
I am going to ceramic coat my exhaust pipe on my j's racing 70rr, but not the canister. I know that it'll be in some high temp oven to cure the ceramic, but i am worry if the canister could get damaged while its in the oven curing? anybody has down this before. Btw $$$ is no issue, working for the company has its perks. ...Will the internal of the muffler be durable enough to handle 300-400 degree temperatures?
BTW thanks GOTUNING for the exhaust..IT's a piece of art, i just want to hang it in my garage as a trophy..haha..its so bootiful!!!
Old Feb 11, 2015 | 08:30 PM
CCPcoatings's Avatar
Why would it get damaged? Your exhaust temps could conceivably range from 550F - 1200F+ under normal driving. The coating process would include thermally degreasing the parts at about 800F. So most all of the SS would yellow somewhat, but this wouldn't really matter since you're coating them.
Old Feb 12, 2015 | 03:23 AM
nizmo_max's Avatar
I guess I'm just worry about the discoloring of the muffler itself. But everything is a go!! I will post up some after pic of the ceramic!!!
Old Feb 18, 2015 | 06:03 AM
gnehc1's Avatar
Where are you getting the ceramic coating from? Is it accessible to the public?
Old Feb 18, 2015 | 06:15 AM
melon_launcher's Avatar
It would not damage the exhaust, maybe discolor it. However, on your street car there is really zero need to ceramic coat your exhaust. Keep your factory heat shield in and you will be just fine. If you're worried about heat soak, maybe gut and insulate the airbox as well as shield it. There is no reason to coat the exhaust itself, even if this were a race car. Only the components which would transfer heat to engine components should / need to be coated (i.e. exhaust manifold, downpipes in turbo applications).
Old Feb 18, 2015 | 01:11 PM
nizmo_max's Avatar
Old Feb 18, 2015 | 01:28 PM
nizmo_max's Avatar
I went through my work place to get it done. Yes its availible to the public but your not in wi. try your local areas.
Turned out really nice!!!
Old Feb 18, 2015 | 08:40 PM
gnehc1's Avatar
It looks good!
Old Mar 13, 2015 | 01:45 AM
Bricktop ivi's Avatar
Nice
YENS2K
Socal Swap Meet
Jun 6, 2010 10:39 PM
2QYK4U
Mar 18, 2006 11:39 AM
NutinbutVTEC
May 19, 2005 06:16 PM
Unicron
Mar 14, 2001 07:44 AM
