Sponsored by: CARiD
Changing DRLs to HID?
Old Oct 19, 2011 | 12:45 PM
calvinnnnn's Avatar
Default Changing DRLs to HID?
I have an 06 and is it possible to change the DRL bulbs to HID or to a bright white instead of the yellow?
Old Oct 19, 2011 | 06:47 PM
steezyap1's Avatar
It is possible to change your DRL to HID, however your high beams will also be HID.
The reason why this is bad is because it is not good for HIDs to run at half power from the DRL. Also, because HIDs take a little time to turn on and that is not good for the high beams as you want them to turn on instantly when needed.
If you leave your DRL/high beam on halogens, all bulbs will still make the DRL yellow because any halogen bulb will burn yellow at half power. So even if they burn white or blue at full, it will have a tint of yellow for the DRL.
Old Oct 20, 2011 | 05:38 AM
robotvoice's Avatar
Run your low beams during the day, problem solved. I have mine on every time I drive.
Old Oct 20, 2011 | 12:08 PM
Bebop's Avatar
^ hahahah
arsenal
Jan 14, 2014 07:18 AM
Kyushin
May 21, 2010 04:51 PM
khiz
Aug 15, 2008 04:35 AM
CarlitoLagman
Feb 8, 2008 07:12 PM
DGBCDB
Dec 11, 2007 03:37 AM
