Cheap Hood Dampers
So i am looking for some cheaper hood dampers and i have seen a thread on these that stopped back in 09 so i kind of wanted an update. Are these still the best cheapies to go with?
http://www.ecrater.com/p/3575481/00-01-02-...-gas-hood-shock
Here is the old thread for reference
https://www.s2ki.com/forums/index.ph...ic=569863&st=0
They look nice and the hood brackets are def better but they retail at $200
http://www.scienceofspeed.com/products/ext...d/hood_dampers/
I just cant bring myself to spend that much
i have the sokie tech ones .. i installed them in christmas time .. which is only about a month ago..
i have the carbon ones ..
they appear and feel to be of good quality ..
installation was easy .. i did have a problem installing them, but then i checked a picture from a previous installation and it was a breeze..
the only problem i have with them is that the dampers are very hard.
when you open the hood/bonnet, if you let it go it literally FLIES upwards. It does slow down at the top, but it gives you a really bad feeling that its going to break or something.
Even when you close it.. you have to make quite a lot of pressure to close it.
On the plus side, it opens up a good 20-30 cm more than OEM. Its like using the old broomstick
Overall I'm happy with them, but I hope that with time, the dampers will not remain as hard as they are now.
Originally Posted by kevos2k,Jan 26 2011, 02:13 PM
Nrg, pwjdm
Are there any other options out there???
