coilover question
hey guys,
i think i finally made up my mind on which coilovers to get and im thinking the KW v3 due to all the positive things i am reading about it on the forum.
couple things:
am i able to adjust camber with these also?
where is the best place to purchase them via online or local? ( i am located in TOrrance, ca 90505)
thanks guys!
couple things:
thanks guys!
hey guys,
couple things:
thanks guys!
couple things:
thanks guys!
in the S camber is adjusted in the suspension. doesn;t matter what struts you have.
bear in mind that they're somewhat soft and have more body roll than other coilovers with stiffer springs.
but with separate bump/rebound adjusters it's easier to tune them for your taste.
Just make sure you get a proper alignment after (or when) they're installed.
Because if he was asking if installing coilovers would keep him from being able to adjust camber, then that wouldn't make any sense at all.
Originally Posted by b0r1cha' timestamp='1351337276' post='22112041
so would i get a significant amout of camber if i lower my car on coilovers? and to fix it would i need a camber kit???
Max neg camber wise, the front allow about a max of -2.8 to -3.0ish. The rears allow for about -4.0 max. If you want MORE camber, you can do something like a J's camber joint in the front to allow more negative, but it sounds like you are concerned with TOO MUCH negative camber. So in that case, don't worry about being able to dial it back to stock specs after you drop it--On this car, you WILL be able to without having to buy anything else.
jst2878
Jul 1, 2014 01:27 AM
