CR sway bars
its the same thing as the my00 ap1....so i tried it on my my06...(i use to own an ap1 and i still have the stock sways that i took off from it and replace it with some aftermarket sway bar)...
anyway my impresion for it in combination with other suspension mods : megan track coilover, x brace, cr rear upper bar that connects to the roll hoops, cusco rear strut bar, cusco lower tie bar. and here my alinment 3deg on all four, 7.5 caster, 0 toe in front and about 3/16 toe rear, tire pressure is 32 psi on all four, 16x8 with 245/45 toyo ra1 on all four. custom rear diffuser.
i think it created some minor understeer and a noticable lesser body roll was achieved (this is tested in a canyon down here in south cali) maybe because this is due to my suspension combo but i fixed the understeer by lowering the front about 5mm and increase rear dampning by two clicks up left and right. and then i also have a spare sway bar links from an ap1 that i modified--i shorten it about 10mm by cutting and then welding them together..
so far i love it...and i am still doing some research and reading how to make this better..
anyway, good luck...
Swiftoy
Originally Posted by RadioZero,Jan 31 2008, 03:37 PM
i have the CR sways but i installed them with the CR spring/shock. so, i can't tell you how the sways work with stock spring/shock.
Originally Posted by PrOsPeCt S,Feb 1 2008, 01:22 PM
are the CR springs a lil stiffer than MY07??
Swiftoy
Jah2000
Dec 12, 2015 08:26 AM
