Sponsored by: CARiD
cusco sway bar and swift sway bar
Old Jun 23, 2009 | 11:47 AM
SoCalAp2's Avatar
Default cusco sway bar and swift sway bar
which is stiffer?
i have both sets in my garage right now, but i don't want to do alignment/corner balance then find out which is better.
i know there is a lot of better sway bars out there, you don't need to tell me, because they are double the prices. And i just need a simple answer
this might be a repost, i searched, but everytime when someone ask about "cusco sway bar" they will throw out other names saying better or blah blah blah
thanks in advance for any useful help.
Old Jun 23, 2009 | 01:13 PM
spook's Avatar
Correct me if I'm wrong, but I'm pretty sure the Cusco is 32mm, and approximately 70% stiffer than MY00. As far as Swift goes, I think I recall seeing that it's approximately 87% stiffer.
I know Tan is running Swift front and rear, and I've seen him vouch for the legitimacy of Swift products.
Old Jun 23, 2009 | 03:58 PM
JSWhaler's Avatar
Yes, the swift is a much better sway bar set.
Old Jun 23, 2009 | 05:11 PM
f20kills's Avatar
I would research some more for sure.
Im not 100% sure, but I remember reading a while back in the R&C forum that the swift front is SOFTER than stock.
Ill look for it in a sec....
FYI, your alignment is not affected during a swaybar swap.
Old Jun 23, 2009 | 05:19 PM
f20kills's Avatar
Here you go
https://www.s2ki.com/forums/index.php?showtopic=571955
Old Jun 24, 2009 | 07:59 AM
S2Kitt's Avatar
I have Cusco front an rear sways an they made a world of difference to me. It was like driving a hole new car.
Old Jun 24, 2009 | 08:28 AM
f20kills's Avatar
IIR, The Cusco is 32mm?
Old Jun 24, 2009 | 09:11 AM
S2Kitt's Avatar
F: 32mm
R: 30mm
Old Jun 24, 2009 | 01:19 PM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
I've had both sway bars.
Cusco 32mm front & 30mm rear (Hollow)
Now I'm on
Swift 26.1mm front & 26.7mm rear (Solid steel)(measured w/ micrometer)
I can say from driving on both the Cusco felt less body roll, but didn't rotate the car very well. It felt a like it wanted to push. The swift feels much more agile along with a good feeling in way of stiffness. I think swifts are much better than stocks and better than cusco because it doesn't change the characteristic of the way S2000s drive but does add more stability in the turns by lessening the body roll.
Kel (Evasive) & Aaron (Gotuning) told me once when I had the Cusco bars, "Big sway bars is poor mans kilograms." Meaning poor man's spring rate. If you want stiffer, than up the spring rate not the sway bar.
corince06
Aug 17, 2011 06:33 PM
S2Kdreamz
Aug 13, 2008 08:39 PM
S2K:-)
Apr 24, 2006 07:05 AM
FRFR
33
Jan 11, 2005 04:19 PM
Alfredo
Jul 20, 2004 04:08 PM
