Sponsored by: CARiD
Custom exhaust question
Old Aug 13, 2011 | 09:05 PM
rugsr's Avatar
Default Custom exhaust question
So I was thinking of my next project, exhaust, and before I go spending cash, I'd like to hear facts.
My plan is this.
Install my PLM header, after the header I fab up an electric cutout, after that my stock cat and then stock catback.
So on days where I want to hear nothing I leave the cut out closed. Then on days I want to hear some noise I flip a switch and it's just headers to open pipe. After the cutout would be another flange and some piping to get the exhaust away from my passenger.
I know this is physically possible, but is it safe. I don't mean for my ears but for my car.
I have heard people say just headers and no backpressure will run the motor and others say it won't be a problem.
Facts?
Also, if back pressure is an issue, could I extend the piping after the cutout to create back pressure? Or would it need a resonator?
Thanks guys
Old Aug 13, 2011 | 10:30 PM
barrett4bama's Avatar
Backpressure is not an issue. Run the cutout and you will be fine.
Old Aug 13, 2011 | 10:47 PM
H22toF20's Avatar
Everything after the collector is a restriction. Unless the header was poorly designed.
Old Aug 14, 2011 | 04:38 PM
rugsr's Avatar
That being the case. If I were to drive the car with just header and cutout by passing the cat and o2 sensor...do you think I would through a code?
Old Aug 14, 2011 | 04:41 PM
importkid's Avatar
Yes. Unless you run a full EMS that disables secondary O2.
Old Aug 14, 2011 | 06:32 PM
rugsr's Avatar
So when it comes time for inspection I can always close the cut out but if I'm throughout a code, will that effect the performance?
Old Aug 14, 2011 | 07:45 PM
H22toF20's Avatar
Correct.
Old Aug 15, 2011 | 07:49 AM
rugsr's Avatar
And if I don't will that ever t the cars performance?
I don't mind seeing a light every now and then
Old Aug 15, 2011 | 10:21 AM
whiteflash's Avatar
I don't think the secondary O2 will limp it; the primary will though. (99% sure )
Old Aug 15, 2011 | 10:47 AM
rugsr's Avatar
If it doesn't effect performance then that's what I'll do.
If it does then I could always put the cutout AFTER the cat... Rather not though
