Sponsored by: CARiD
DIY: Ground Control top hats
Old May 29, 2012 | 12:59 PM
  #21
JBAutosports's Avatar
Former Sponsor
Originally Posted by Duke Togo
since the kw v1's don't come with top hats I picked up some from ebay
Duke - Did you get front and rear? Any clearance issues with the filler neck in the rear? Did you have to modify these civic ones to work? Thanks!
Old May 31, 2012 | 12:20 PM
  #22
Duke Togo's Avatar
There was no modifications to get the v1's I am using to work, standard konis should be the same - I used the oem top hat bushings instead of the hard plastic ones it comes with and switched out the KW bumpstops for some konis I had - it comes with some that will ride up into the top hat too though.
At the rear I didnt have any issue except the one nut thats on the drivers side front is always a pita helps to have a retractable magnet case you drop it - the oem honda nuts don't fit so I picked up some from autozone.
UK Paul
Mar 14, 2017 10:43 AM
EvoEddie
Nov 16, 2014 03:53 AM
skip2mylou
Apr 4, 2012 01:48 AM
Ebi17
Dec 28, 2011 08:37 AM
Boofster
Feb 29, 2008 01:52 PM
