Sponsored by: CARiD
Downforce or Custom?
Old Jan 3, 2011 | 03:58 PM
Booztin's Avatar
Default Downforce or Custom?
I bought some 18x9.5 +22 te37s all the way around.
For the front im most likely going to run 235/40/18 size tires.
Im aiming to close any gap between my front fender and tire to give you an idea of ride height.
Im between two options to make them fit , also keep in mind ideally i dont want to run more then -2 camber in the front or less if possible.
First option is buy some downforce fenders i know their 30mm wider each side I tryed searching i havent been able to get specs for anyone running them with agressive rims. Tire sizes , camber, etc.
Option number two is take it to a shop and have the
Custom widen my front fenders in order to fit my rim/tire choice at the camber I want.
If anyone has some expeirence or knowledge on this feel free to shed some light.
Old Jan 3, 2011 | 10:20 PM
Crazyfootcoy's Avatar
i have 285-35-18's with +55 offset with my downforce fenders and they fit pretty flush but my camber is still factory. idk if that helps but the more you know
Old Jan 4, 2011 | 12:09 AM
Booztin's Avatar
Thanx for the input it all helps .
Old Jan 4, 2011 | 12:16 AM
TRD_Celica's Avatar
get the downforce fenders
Old Jan 4, 2011 | 03:00 PM
clarkster009's Avatar
That is pretty aggressive fitment. Some guy was running 17 x 9 +38 (https://www.s2ki.com/forums/index.ph...=691689&st=125) and looks like it is getting pretty close. I think the Js fenders are 40 mm and people are running that sizing.
Old Jan 4, 2011 | 03:03 PM
Another pic of them:
Old Jan 4, 2011 | 06:00 PM
Booztin's Avatar
If i do get them custom done im prolly gonna go 45-50mm wider on each side.
Im hoping with that i shouldnt need to run that much camber or worry about cracking them.
Guess custom is the only way to go
Old Jan 5, 2011 | 08:57 AM
Yeah let me know what kind of quotes you get on custom metal widening man
Old Jan 5, 2011 | 09:03 AM
GT Motoring's Avatar
Former Sponsor
We run our Challenge carbon wide fenders that are 30mm wider than oem. The Time attac car uses 18x9.5 +45 with 265s all around. It fits pretty perfect. +22 with the same tire wouldnt work for sure on ours at least. Not sure with the stretched tire... might still need camber.
Old Jan 5, 2011 | 11:54 AM
Booztin's Avatar
probably gonna be looking at the 1500-2000 range for it done the correct way.
