Easiest way to adjust rev limiter?
Hey guys, just a quick question.
Im hoping someone has some experiencing with adjusting the rev limiter the easiest way. I'm not looking to adjust any fuel, so even though I will probably have to get a SAFC II. I'd like to see if anyone knows of a better way to reduce the rev limit. My application is that I'm running a AP2 engine with an AP1 ECU and want to ensure I don't rev past 8k.
Thanks
Thanks
I would assume the bee-r would solve any over rev issues even when downshifting? I havnt gotten around to throwing mine on yet but I would like even on a downshift over reving would be stopped assuming the limiter was set correct?
There is nothing you can do for a miss shift/mechanical over rev. That’s purely on the driver.
I run an ap1 ecu with an F22. That ecu ramps up the fuel very quickly from 8 to 9krpms, and F22 power peaks just after 8k. You can feel the power drop off pretty rapidly after 8200-8.5k and so that’s when you shift. Rarely do I ever hit the rev limiter except if I over run to get to the next corner at the track, and the motor takes the rpm just fine. Would I make a habit out of revving it to 9k? No I wouldn’t suggest it as im sure it will ovalize the bores overtime and shorten the life in the long term. 8500rpm is the equivalent ap1 piston velocity so that’s where im most comfortable long term. Mechanically the rods and everything else will take the 9k rpm however.
No. A rev limiter cannot work on downshifts. In the case of a downshift over rev, the wheels are powering the engine. Unless the limiter can disengage the clutch, the engine is along for the ride.
