Ebay short shifter.
so i have notice this rattle for a while now. not sure if it has been there since the installment of the C's style short shifter or it has been developing and i recently took notice. i had a friend install it for me while i was gone. he was replacing my clutch, i told him go ahead and install the short shifter. when i came back everything was fine. but, i didnt like using allen heads on the bolts on the part that holds the shift shaft down, should have left those damn things alone. well, this is way back when i was a noob about EVERYTHING. i got screws that "kinda" fit. they were sae not metric. so i pretty much ended up stripping the two or all three of the bolt holes. well i remember two were ok, but one was pretty much stripped. i did end up buying the right size screws, i wanted hex heads. i had to use loctite on the stripped hole.
my questions are:
1. is it the shifter fault that it is rattling?
2. is it because only two of three screws are holding it in?
3. could i just retap the hole to fit a slightly larger bolt? and would metal shaving get into transmission?
thanks
alan
sub question for moddiction: if it is my shifter and all i need to do is replace the damn thing, WHEN THE HELL ARE THOSE SHORT SHIFTERS COMING OUT?? lol i have been waiting forever!
my questions are:
thanks
alan
Hey man. Mine did the same thing and actually the shifter itself broke in half basically so was the metal on the inside rattling against each other. Hopefully not the same for you though.
Originally Posted by ans2k,Sep 18 2010, 04:23 PM
If it broke in half, how does it still shift?
It's pretty easy to pull it out and take a look. Just those 3 bolts holding it in and then pulls out.
if you do pull it out make sure to have it in neutral when you do.
