View Poll Results: Which header?
Hytech
0%
Voters: 3. You may not vote on this poll
Exhaust setup thoughts
Hi guys,
Just wanted an opinion on the exhaust setup I'm thinking about:
T1R 70-EM Sparrow dual
Berk HFC 70mm
Tossing up between the Hytech N/A header and the toda torquie-kun header.
Planning to supercharge in about a year or two, so just curious of this selection of parts could a reduction in performance when i do get an S/C.
Also curious if anyone has run into fitment issues with these parts or any combination of them.
Thanks
Berk HFC 70mm
Thanks
I voted for the toda. Those three items would make a really nice exhaust setup. A lot of people will tell you to go testpipe for the best power (which is true) but a hfc or a resonated testpipe will help keep the sound down without sacrificing much power. It will be a good setup to support a supercharger.
I'm very happy with my Toda Torquie Kun header. Currently have it bolted up to a Berk 70mm HFC and a Tracy Sports 60-70mm single. I also had/have a GReddy SE 70mm dual, similar to your T1R, but I found for my taste it was a little loud. I let a friend borrow the GReddy without the I/H/HFC and it's a bit quieter. I found by adding the header and HFC it changed the tone of the exhaust and made it a bit louder if that matters to you.
See my sig for what I'm running. I love the sound of my exhaust more than any other I've heard. It may be a bit loud if you havent added any sound deadening material, but I would recommend doing that before adding any exhaust. If performance is what you are after, don't even bother with NA mods. Just save your $$ for FI
T1R 70 EM dual required me to do some minor tweaking to get both tips to be centered. I will say that the welds are quality, and the metal is high grade, because doing some bending to the hangers without the right tools was quite a task. The T1R header had some fitment issues (the guys at boost logic suggested that the welded the parts together without it being mounted to the jig causing a slight warping in the mounting surface due to heat) but AJR/Evasive worked together to hook me up with an extra thick header gasket to seal any possible exhaust leaks. I can only speak for T1R parts- fitment is not OEM for their parts.. or maybe I just had bad luck. If I could do it all over again I'd still go with the T1R 70EM dual just for the sound.
R Legend
Apr 6, 2010 10:05 AM
