Sponsored by: CARiD
F22 and f20 engine difference
Old Jun 12, 2012 | 10:41 PM
henrryxd's Avatar
Default F22 and f20 engine difference
ive been searching around but i dont seem to find the answer..
are f22 and f20 engines identical while looking at it?
or is there specifics difference when ur trying to distinguish them too.
the reason y im curious is because the previous owner claims theres a ap2 engine in there. when i look at the engine it looks exactly like the ap1 engine. the only differance i see is the gold piece on the top but that piece can be replaced at anytime.
does anyone know or have any pictures that will tell the difference.?
Old Jun 13, 2012 | 03:35 AM
charliec225's Avatar
https://www.s2ki.com/s2000/topic/883...ion-on-engine/
Old Jun 13, 2012 | 06:36 AM
henrryxd's Avatar
thanks, but is the vin # the only way to tell the difference?
Old Jun 13, 2012 | 09:03 AM
MBHs2k's Avatar
It's not the only weigh but it's definitely the most reliable way.
Old Jun 13, 2012 | 09:56 AM
dc2-2-ap1's Avatar
the motor has f20 / f22 stamped on the block (depending on which one it is). That stamp is near the intake manifold where the head and block meet. The only markings on the head that I know of is the vin. Best way would be to check both.
Old Jun 13, 2012 | 10:25 AM
AP100_JA's Avatar
Just like dc2 said. If you are looking at your engine, the stamp should be in the front right where the head n block meet, I'll post a pic of my f22 ap1 later tonight
Old Jun 13, 2012 | 10:36 AM
PndaS2K's Avatar
- Ap1 2.0L, 8800rpm rev limiter , fuel cut off 9000rpm.
Bore/ Stroke-
87.0 mm (3.425 in) x 84.4 mm (3.323 in)
- Ap2 2.2L, 8000 rev limiter, fuel cut off 8200rpm.
bore/ stroke-
87.0 mm (3.425 in) x 90.7 mm (3.571 in)
Hope this answers some of your questions!
Old Jun 13, 2012 | 10:41 AM
S2K-F8's Avatar
Bore/ Stroke-
bore/ stroke-
How can you tell the rev limiter and bore/stroke by LOOKING at the engine
Old Jun 13, 2012 | 10:53 AM
Gernby's Avatar
Former Sponsor
Bore/ Stroke-
bore/ stroke-
Doesn't help the OP, but the rev limiter and fuel cut are the same thing. On the AP1, it is 8900 RPMs, and on the AP2 is it 8200 RPMs.
Old Jun 13, 2012 | 06:37 PM
PndaS2K's Avatar
Originally Posted by S2K-F8
Originally Posted by PndaS2K' timestamp='1339612591' post='21778871
[quote name='henrryxd' timestamp='1339569663' post='21777412']
Bore/ Stroke-
It's called Wikipedia
bore/ stroke-
[/quote]
