Sponsored by: CARiD
F22c cams in a F20C
Old Apr 22, 2011 | 12:42 AM
Boomer22's Avatar
Default F22c cams in a F20C
Has anyone done this? Can it just be installed or must the valves and retainers also be done? What power and torque gains are made?
Old Apr 22, 2011 | 04:05 AM
dc2-2-ap1's Avatar
no power gains will be made. the f20 cams will make power in a f22 so theoretically you will lose power by putting f22 cams in a f20. The f20 cams have a more aggressive lobe. but if you are set on doing it than the answer to your question would be no the retainers and valves do not need to be swapped- it is just a bolt up affair.
Old Apr 22, 2011 | 05:53 AM
suzuka-blue-s2k's Avatar
What a lot of people have done is put an ap2 exhaust cam into their ap1, and the ap2 guys put an ap1 intake cam in their ap2. Supposedly the best combination on the f20 or f22 is an ap1 intake cam, and ap2 exhaust cam. I almost did this since there was a lot of talk about how it will give you gains, but after tons of research there is such a small difference it isn't even worth doing the swap. I would save your money but if you decided you want to do it, you can use your stock valves, springs, retainers, ect..
Old Apr 22, 2011 | 06:31 AM
Boomer22's Avatar
Thanks huys. I just read somewhere, someone replied that it gained power but I had to make sure on s2ki. There's no point doing it then
Old Apr 22, 2011 | 10:50 AM
DFWs2k's Avatar
What marking does the ap2 exhaust cam have on it
passmans2kny
Jun 1, 2013 07:58 PM
it'S2klean
May 12, 2011 06:10 AM
nsx_bob
Dec 9, 2010 01:56 PM
slammed ap1
Sep 3, 2008 08:02 PM
Soul Coughing
Dec 5, 2007 07:36 PM
