Final Drive Gears and Smaller tires size
I've been reading that running a smaller tire size, specifically ap1, will improve acceleration like gears. i'm asking because i'm running 225/45/16 in the rear which i read is like having 4.44's. this week i'm having 4.44's installed, just wondering with this set up what will the gear feel like? 4.56? more?
i hope i'm posting this in the right place.
Thanks, Brian
Thanks, Brian
Originally Posted by DeadZero,Nov 10 2008, 11:11 PM
im not sure about it making it faster but i do know its gonna mess up your spedometer on the car tho
Yep, smaller diameter tires will give you the equivalent of a shorter gear, and reduce your unsprung weight a bit, too. The stock AP1 rears run 840 revolutions per mile, while the Yokohama Advans, for example, run 872 revolutions per mile, 3.8% shorter. Running that with the 4.44 will give you the equivalent of a 4.61 gear.
[QUOTE=rev_2_9k,Nov 11 2008, 05:36 AM] Yep, smaller diameter tires will give you the equivalent of a shorter gear, and reduce your unsprung weight a bit, too. The stock AP1 rears run 840 revolutions per mile, while
Originally Posted by S2Kage,Nov 11 2008, 10:07 AM
I was contemplating this with 4.77s and larger tires.
