Sponsored by: CARiD
Front undertray
Old Dec 24, 2012 | 08:23 AM
Kyushin's Avatar
Banned
Default Front undertray
Does anyone else make a front undertray similar to this one by beatrush http://www.kamispeed.com/Beatrush-Un...br.s540600.htm
I think $400 for a sheet of cut aluminum is alittle rediculous ffs, theres not even an ASM sticker on it.
Old Dec 24, 2012 | 08:30 AM
black_EM1's Avatar
WASPComposite makes carbon fiber front splitter for around that. Hell, if you know a metal guy, you can probably make it yourself.
Old Dec 24, 2012 | 08:36 AM
freq's Avatar
Originally Posted by S~Factor
Billy aka Need Powder Coating with a custom full length CR Lip Splitter/Diffuser.
Before pictures:
Being super low to the ground, the front lower cover, splash shields, and fender liners have seen better days.
After:
Replaces front cover and splash shields and will better protect the front intercooler from damage when bottoming out.
Flushed mounted with the CR lip.
Couldn't help do a little photoshoot.
The rest of the pictures: https://www.s2ki.com/s2000/gallery/a...user-projects/
Old Dec 24, 2012 | 09:23 AM
Kyushin's Avatar
Banned
Very nice, whats the weight on that one? Id assume the louvers on the beatrush tray really arent functional?
Old Dec 24, 2012 | 09:50 AM
freq's Avatar
Maybe for draining water they're functional? I assume weight would be minimal. Hit Ray (S-Factor) up, he's an easy guy to work with.
Old Dec 24, 2012 | 10:41 AM
Driven's Avatar
plywood. $20. works just as well as the metal ones, but is slightly heavier...
Old Dec 24, 2012 | 02:24 PM
DR. FEINSTONE's Avatar
sfactor's aluminum underbody panel is cost effective method, alloy craft or gladman makes a similar item I believe. But, aluminum or plywood is heavier than carbon/dry carbon version.
Aluminum panel will have a lot of noises from rocks and whatever your car comes in contact will on the road surfaces. Carbon underpanel is less weight, noises from rocks on road surfaces but it is expensive compare to the aforementioned.
I have the pwjdm dry carbon front under panel and it is weight around 4.15 lbs, very light but it is expensive. The underpanel will help your car stability at high speed endurance. I have cr-lip, pwjdm dry carbon front under panel, spoon sports rear bumper and carbon diffuser. It is very stable at high speed endurance in the triple digits
I will post a picture when I get home
DR. FEINSTONE
Nov 11, 2009 12:24 PM
amaymay_s2k
Oct 4, 2009 01:01 PM
