Sponsored by: CARiD
Glasspack/Cherrybombs on an S2?
Old Dec 10, 2010 | 09:00 PM
UNDFTD1's Avatar
Red face Glasspack/Cherrybombs on an S2?
I'm looking to make a really far out there exhaust for my current track car, I'm looking for a really deep/exotic/agressive tone.
I hate canister exhausts and how they sound/look. Has anyone ever played with cherrybombs/glasspacks or any special resonators for your exhaust systems that you would recommend?
Old Dec 10, 2010 | 09:08 PM
KLASMID's Avatar
if you go threw with this POST A VIDEO!
Old Dec 10, 2010 | 09:16 PM
UNDFTD1's Avatar
I am
here was my last exhaust setup:
[media]http://www.youtube.com/watch?v=-0X9rbY8sh8 [/media]
me bouncing the rev (nowhere close to any high rpms)
ap2 exhaust turned into a single exhaust catback, capped off with a custom muffler/tips at the end, it still retains the stock resonator etc.
Old Dec 10, 2010 | 09:53 PM
rrounds's Avatar
Stay away from glass-packs, they use 50 year old technology and will give the "S" way to much back pressure. Thats a sure fire way to make less hp.
We did use this race muffler(3 1/2" in and out, it bolted up to the collector) it did not make it quiet at all but it did let the car pass the db limit that the track had. These mufflers offer a 5 - 7 db drop over open collectors and the mufflers flow 850 C.F.M
http://www.moroso.com/catalog/categorydisp...p?catcode=35054
ROD
Old Dec 10, 2010 | 11:58 PM
UNDFTD1's Avatar
thanks ROD!
great input, do you happen to have any finished pics of the exhaust?
accepting more suggestions as well!
Old Dec 11, 2010 | 03:30 AM
chef-j's Avatar
Maybr vibrant?
Old Dec 11, 2010 | 09:44 AM
rrounds's Avatar
Originally Posted by 2ndTimeAround,Dec 11 2010, 03:06 AM
Have you seen the inside of a glass pack? They are about as straight through as any N1 style muffler, but with fiberglass packing and less of it.
This is off of another web site
Which muffler flows the best?
Supposedly this review was performed by Martel Brothers:
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
The mandrel bending of the pipes done by aftermarket exhaust companies is good for 2-4 hp depending on the severity of the stock bends. Most local exhaust places don't have a mandrel bender so changing the pipes out doesn't do anything if pipe size it not increased.
My opinion, if its more noise and a little more power just add the best flowing stainless muffler to the current system and never do it again. If you increase pipe sizes, then a local shop and only stainless. Don't care about money but want ease and better gains than most local shops can offer with no pipe size increase, and aftermarket exhaust.
NOISE does NOT equal POWER!!!
Which muffler is quietest but makes the most power?
This test was performed by 5.0 Mustang & Super Fords Magazine, December 2002 issue (page 55) on a '90 Mustang LX coupe with 370hp and 11 second potential. 66 pulls were made for this comparison:
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
2 ½” Cherry Bomb 294 CFM, that my friend is very restrictive.
ROD
Old Dec 11, 2010 | 11:08 AM
K1ngfunK's Avatar
From: The land of corruption, cachaça, and caipirinhas.
FYI, I just recently purchased the Asura 3" dual exhaust and it sounds unlike any other exhaust I've ever heard for the S2000. It's got a VERY, VERY deep, low rumble at the lower revs, nearly silent at idle, but it absolutely roars once you bring the revs up. All-in-all, it has a very mature sound, and there are many dyno graphs to show its performance-boost, too.
Old Dec 11, 2010 | 11:13 AM
flyingtoaster's Avatar
I have a resonated test pipe and a resonator on my T1R exhaust and it sounds deep and quiet with the muffler on. With the muffler unbolted, it has an aggressive glasspack sound. Also, the SRT-4 has a unique exhaust with only resonators and no mufflers and I'm sure you know how they sound- aggressive and poppy. I would suggest maybe a resonated test pipe, and a custom exhaust with two resonators and no muffler.
Old Dec 11, 2010 | 11:29 AM
rrounds's Avatar
Originally Posted by UNDFTD1,Dec 11 2010, 12:58 AM
thanks ROD!
My "S" has the stock exhaust on it.
My old dragster(170" sling shot front engine rail) had the moroso mufflers on it.
I will put one Hooker Aero Chamber muffler on my car to see what it sounds like, if it sounds good then I'll put the other side on, if it sounds like caca then I'll try some other muffler. All I know is if you want your car to sound different than all the others you have to try mufflers that nobody else has tried on the "S".
I have a supercharged 3.8L that has a 3" exhaust that splits in to two 3" Hooker Aero Chamber mufflers and that car has won two trophies for best sounding exhaust on a 3.8L at some car meets that my wife and I go to.
ROD
