Grouding Kit?
Anyone have a grounding kit installed on their car? does it really do what they say it does????
http://www.vividracing.com/catalog/c...sal-p-403.html
From research, the S2K does not need the grounding kit.
I have rewired a few Hondas to include 2 wire tucks on S2Ks and have not seen any electrical component that was not grounded. The ONLY area on the S that might need a ground strap is the exhaust.
But, use your own judgement after researching.
Best success,
Best success,
An easy way to check components is to use a multimeter (Ohm's side). Electrical component to Ground. But first disconnect the neg (-) terminal at the battery. If the Ohm's to ground is other than 0.000 then check for proper grounding.
