Sponsored by: CARiD
hard top fitting kit advice
Old Jan 15, 2012 | 10:18 AM
ConnieS2k's Avatar
Default hard top fitting kit advice
hi people
need some help here, ive just brought a hard top and am looking to get a fitting kit for it. can i get away with just buying just the side brackets that it attatches to and the brushes to go on the pillars. or will i need to buy anything else to make it work?
please help with some coments
thanks james
Old Jan 15, 2012 | 07:34 PM
NFRAP2's Avatar
You didn't mention of your hardtop is OEM or aftermarket, what you need varies a little depending on which. Assuming the hardtop has the front latches already attached, all that you need for it to safely stay on the car is the side brackets. If it is an OEM hardtop and you want the rear defroster to work, you may need an additional wiring harness to connect it. To prevent rattling of the front latches and wind noise, you will want the strikers that are made for the hardtop, but this isn't 100% necessary. You can buy aftermarket hardtop fitting kits from vendors on this forum, but they are not as quick and convenient as the OEM kit for hardtop removal. The OEM fitting kit is ridiculously expensive, so I made sure the seller included it when I bought my hardtop from them.
Old Jan 27, 2012 | 07:46 AM
ConnieS2k's Avatar
Hi thanks for your help.
Yes I'm sure my hard top is a OEM one, has rear heated screen and the front latches.
Also do you have to remove the soft top and frame to be able to fit the hard top?
Struggling to find a fitting kit in the UK for a good price.
Old Jan 30, 2012 | 09:03 AM
ConnieS2k's Avatar
Bump, come on people help
Old Jan 30, 2012 | 12:21 PM
MeganFoxAP1's Avatar
You do not need to remove the soft top and frame to be able to fit the OEM hardtop or most aftermarket hardtops in general.
Old Jan 30, 2012 | 01:17 PM
chViETnk's Avatar
so you have the front latches but are missing the rear mounting hardware? there are 3 different ways you can go about this. you can either source out oem rear hardware or the cheaper route is to go with the izzy brackets(not the race one if you want to keep the soft top in) or aftermarket brackets are available from venders.
and no you do not need to remove your soft top, just have to put it down
regmilla
May 19, 2005 03:02 PM
