I just got a ViS hardtop and the window seals are kinda crappy. For those that have replaced them, what did you use? Also, will OEM hardtop window seals work?
I just need the following, correct?:
#1 (x2) CLIP
#9 WEATHERSTRIP, R. ROOF SIDE DOOR
#14 WEATHERSTRIP, L. ROOF SIDE DOOR
#20 (x4) GROMMET ASSY., HARDTOP WEATHERSTRIP
#21 (x2) SCREW, TAPPING (4X10)
#23 (x2) SCREW, TAPPING (4X20)
OEM, I was quoted $350 a side by Honda Australia, so I decided to put my own setup together. Works perfectly well without the OEM cost, so it can be done.
I was able to source from a rubber and plastics manufacturer, what you see above is actually 4 individual pieces contact adhesive'd into place. If you look closely at the first pic you can see the 4 pieces (starting from the outside to inside of the car).
Hope this helps.
Here are some pics using contact adhesive, apply in order of pics. The small square piece as in the first pic above isn't shown here, just the 3 main seals. lmk.
