Sponsored by: CARiD
Help With Fender Roll
Old Aug 31, 2012 | 02:54 PM
skyler2k's Avatar
Default Help With Fender Roll
Hey guys my car is in the shop getting some work done and I was going to have them roll the fenders I was looking into lowering springs .75 or 1" I was going to go with 225 in the front and 255 in the back. The rims are 17x7.5 with +45 offset how much would I need the fenders rolled for it not to rub?
Thanks
Old Aug 31, 2012 | 06:39 PM
Islandroots's Avatar
I don't think you're going to rub with that setup
Old Aug 31, 2012 | 06:46 PM
Jag528's Avatar
I'm running 8 inch in front and 9 on the back with 225/255 and no rubbing at all. I am on stock ride height though. If you lower it you will probably need a light roll with bumper tab relocation.
Old Aug 31, 2012 | 08:32 PM
skyler2k's Avatar
I figure I'll need to roll a little once I"m lowered but about how much is a little in terms of fender rolling? Can I just tell the body shop a little, or do I need to tell them a certain amount?
Old Aug 31, 2012 | 11:41 PM
chViETnk's Avatar
tell them you want it rolled but not flared out, etc. you should be fine.
Old Sep 1, 2012 | 07:10 AM
Jag528's Avatar
I'm no fender rolling expert but I don't think there's different amounts of roll. I'm pretty sure it's either rolled or not. You will also need to have the tab relocated which isn't too difficult.
Good luck with your setup, I never actually did a fender roll but I did a ton of research when I was shopping for wheels.
Old Sep 1, 2012 | 10:46 AM
Manga_Spawn's Avatar
Site Moderator
You are going to have 17x7.5 wheels all the way around? And you are going to put a 255 tire on that? That's going to look like crap. You should be running at least a 8.5 inch wide wheel in the rear.
Old Sep 1, 2012 | 08:51 PM
2000ths's Avatar
yeah, you can definitely roll the fenders to varying degrees. you can fold the inside lip of the fender only slightly or all the way to flat. after it's rolled flat then you begin to pull the fender beyond that. there is also a difference between rolling the fender just at the top of the fender's arc, then going down on the leading and/or trailing edge of the fender as far as you want.
Old Sep 3, 2012 | 06:22 AM
mo19249's Avatar
I dont think you will need fender rolling with that setup either. But if you must, go to/msg OLEGATOR. Great guy ! ! !
He did mine and half of the owners in mid-A. Very professional, reasonable rate and does an amazing job. Dont think he is someone out of the garage, his garage is a freaking SHOP, with lift and everything you can imagine.
Old Sep 3, 2012 | 06:57 AM
Dreaming_S2k's Avatar
If you decide to get them rolled, I'd just tell whatever shop you go with that you want your fenders rolled flat, with NO pull.
