Help: Snorkel installation
Hi,
I've searched the forum in order to find this information and I found a very useful thread:
https://www.s2ki.com/forums/index.ph...ic=317889&st=0
However, the "Installing a CAI snorkel" link doesn't work: https://www.s2ki.com/forums/index.php?showtopic=118787
Can anyone help me on this?
Thanks!
Thanks!
It's should be easy u have to put the duct all the way flat to the left of the hood clipper (wteber that call) the big part will have space to go down from there ....after that Just move it to the left ....let me know if u get it ...if not I will take a pics from my car for U
Originally Posted by Sinji,Aug 21 2009, 07:01 AM
you can just cut an opening in the airguide and leave the rest there and that will also work properly. only remove the airguide if you have a cooling plate...
Another question: did anyone drill a hole in the snorkel so that the water that goes in can flow and not enter inside the air box? I don't know whether my question is clear...
Originally Posted by rgoncalves,Aug 21 2009, 11:32 AM
Thanks!
Originally Posted by rgoncalves,Aug 21 2009, 05:07 AM
Thanks, AirWick! In that case I would have to remove the OEM cooling plate, right? I was thinking about opening a hole only on the left side. Isn't it possible for the snorkel to go down from there?
