Sponsored by: CARiD
HFC Install
Old Nov 24, 2009 | 07:26 PM
chuhsi's Avatar
pb blaster soakings
snap the bolts open with a long wrench (use an extension if posible) instead of slowly pressing them open
Old Nov 24, 2009 | 09:59 PM
Moddiction's Avatar
Former Sponsor
Just unbolt the 5 bolts I think holding the stock cat in and put the new one in, bolt up. Done.
Old Nov 25, 2009 | 08:58 AM
Neutered Sputniks's Avatar
Unplug the O2 sensor from above the transmission and you won't need any special tools to pull it out. Just a big f'n wrench (23mm?). Once you have the stock Cat out (it's heavy btw, watch yourself), you can easily remove the O2 sensor and swap it into the HFC while it's off the car. Bolt up the HFC and then plug the sensor back in.
The Berk HFC comes with the O2 sensor fix built in, so you shouldn't need to worry about it throwing a CEL.
Old Nov 25, 2009 | 09:10 AM
ou818's Avatar
The application of a little heat with a blow torch to the bolts helped me get mine off.
Old Nov 26, 2009 | 02:56 PM
Luke 813's Avatar
Thanks for all the guidance guys. Got it installed yesterday and overall it went pretty smooth, hardest part was prying the stock bolts loose. Definitely notice a sotp difference, I'd say I'm a happy Berk customer. Just need a new set of brake pads and I'm set for the 2010 motorsports season!
S2kNY
Dec 14, 2014 02:00 PM
SweetPizza
Mar 5, 2013 07:33 AM
stradleboy
Jul 20, 2011 05:23 PM
manuelisfun
Jul 31, 2010 09:08 PM
Zoomie
Sep 2, 2009 08:11 AM
