Sponsored by: CARiD
HID highbeams?
Old Jan 24, 2010 | 06:26 PM
Mr. LEG's Avatar
Default HID highbeams?
I have searched and could not find an answer.
I am looking to get 55W HID's and will have the OEM ones left. Has anyone put these into the high beams? If so how was the installation? What are your thoughts?
Old Jan 24, 2010 | 06:33 PM
crank's Avatar
there is a huge thread...just dnt know the name or link lol i am sure someone will help tho, good luck brah
Old Jan 24, 2010 | 07:06 PM
zeroptzero's Avatar
I often wonder why people even bother, I've logged a zillion miles driving in my lifetime, I can't recall using the highbeams for more than a few minutes in total. If you live in an area that requires using them frequently then go for it, but I just can't see the need for them based on my situation. You're low beam HID's will give you plenty viewing area.
Old Jan 24, 2010 | 07:35 PM
justind's Avatar
i use my highbeams all the time, but i also live out in ranch country lol
Old Jan 25, 2010 | 02:00 AM
rioyellows2k's Avatar
I tried this on my MY05, and I blew a fuse. You'll need a lower wattage kit I think. It made the OEM Lowbeam HID flicker with no light output.
Old Jan 25, 2010 | 07:38 AM
Mr. LEG's Avatar
Ok thanks for your responses
I currently live in Lakeland Fl, which some areas are pretty rural. but I may be moving to California and will be driving through mountain areas often to visit family.
Also is there issues if I have to turn them on and off frequently?
Old Jan 25, 2010 | 01:29 PM
Globe182jp's Avatar
to clarify do you want to replace your halogen high beams with HID bulbs? or do you want to upgrade the OEM hid low beams with higher watt bulbs?
Old Jan 25, 2010 | 02:38 PM
irv_usc's Avatar
your best bet to get HID highbeams is to buy an HID kit.
you need a proper wiring harness that taps direct power from the battery in order to power the ballast.
Old Jan 25, 2010 | 04:05 PM
spets's Avatar
Question is, do you mostly flash the highs, or actually leave them on?
HID lights react poorly to being flashed. they don't like to be turned on and off rapidly. But if you leave the highs on, then it may be a nice upgrade.
Old Jan 26, 2010 | 12:24 AM
Globe182jp's Avatar
I asked what you ment because an HID system is not just the bulb, Our cars HID system is great because of the projector not just the bulb.
If you stick an HID kid into a reg halogen housing( our high beams) all you will do is blind everyone and send out soooo much light in random directions that it will do little to increase your vision.
HID's need HID projectors.
Those horrible hid kits wont last long and are re-based on halogen sockets. They are not on any OEM quality, look if they give you a 1 year warrenty do they expect it to last longer than that.
And in response to the flash, no you cannot flash HID lights, that's why it takes our light time to brighten up.
Cars that have HID high beams use a solenoid to move a reflector when it is flashed to high.
Jake
