Hondata IMG
so i live in a really hot country..cant get an after market intake unless its CF cause it will be useless..so im getting a snorkel with a drop in filter
thinking of gettign a Hondata IMG.
Good buy?
worth the extra work on installing it?
reduces monifold heat? or ?
Good buy?
Did mine a couple summers ago when I was living in Vegas. Definitely can tell the difference. Do the whole shebang (Fan Switch, Thermostat, Rad Cap, Hondata) to get all the benefits.
I had no bogging from heatsoak after the install......none.
-Hockey
-Hockey
The manifold is pretty difficult to remove, it will take you 3 hours to remove and reinstall probably, if you have tools and experience with cars. I dont recall what the gasket material is made from. I've had to retorque mine quite a few times since the plastic compresses over time. One of the back nuts is impossible to get anything but a gear wrench on, so it can't be torqued either. Its a half day job but worth it.
Originally Posted by luisS2K,Dec 20 2007, 02:14 AM
the stock intake gasket is metal.
go to s2000.org..they have a step by step DIY of this..pretty good,a nd worth it...and i agree that when you do this its beter to change the thermostat,fanswitch,rad cap, and may i add a raditaor breather tank--it helps a lot in my opinion and you should locate it in the highest place in the cooling system; it will allow a more efficient way to fill and maintain the coolant system while evacuating any air from the cooling system.) but the hondata img gasket alone will help alone by itself already.
