HOW TO: Lambo doors installation
i bought a set of used lambo doors hinges, the only thing it didnt come with wire extensions, there is no welding involved, this is how i did it... hope you guys like them!!
it took about 3 hrs each door
tools:
ratchet
10mm socket
12mm socket
13mm socket
7mm allen wrench
soldering gun
electrical tape
dremel (to cut the fender)
remove the fenders, door and OEM door hinges make sure you unplug the wiring for the doors
install the lambo door hinge to the frame and the door
adjust everything so it lines up with the fender and door frame
find the two similar wires and mark them before you cut them
cut and strip the wires
solder the longer wires to the other wires, then tape them or use shrink wrap, but keep in mind that is a lot of them
before you install the fenders on the car you have to cut the inside of the fender, if you dont when you try to open the door you might damage the fenders and put a big dent on it.
now you just have to install the fenders back on the car...
tools:
ratchet
10mm socket
12mm socket
13mm socket
7mm allen wrench
soldering gun
electrical tape
Originally Posted by Almost Tactful' date='Jan 25 2009, 11:15 AM
i know that not everyone is going to like them, must of you have the S2K for track, i want mine more for show. they are heavy i tell you that...
