Sponsored by: CARiD
How to tighten coilover top hat nut?
Old Mar 26, 2009 | 02:47 PM
akimoto168's Avatar
Default How to tighten coilover top hat nut?
How do I tighten coilover top hat nut without spinning the shock shaft? They are on the car now, and I can't reach my impact back there to tighten the nut. The top allen key is used for dampening adjustment, so I am not sure how to hold the shft still. It went loose and over bumps, the rear clunks. Thanks
Old Mar 26, 2009 | 03:49 PM
Nickamsweet's Avatar
if you can't get to them easily then maybe it's best to just remove the coilover itself... it may be a bit of a PITA but it's safety at the end of the day! get 'em torqued up good and proper this time around though to save you having to do this all over again...
Old Mar 27, 2009 | 06:19 AM
pputkowski's Avatar
Is there a hex indention in the top of the "shaft" that has threads on it? If so stick a hex wrench on there and use that to hold it all still while you tighten the nut.
Old Mar 27, 2009 | 12:44 PM
akimoto168's Avatar
hey thanks guys! There is a hex hole at the top, but it is used to adjust the dampening. Can you still do this?
s2k_Doug67
Feb 25, 2015 09:10 AM
Wiggum
Dec 28, 2011 03:04 PM
Chris_Lum
Oct 5, 2010 10:18 AM
donger274
Feb 13, 2007 01:30 PM
