Sponsored by: CARiD
Install LED fog light for AP2
Old Nov 26, 2014 | 08:58 AM
dakao's Avatar
Default Install LED fog light for AP2
I have question about what 12V power source from the fuse box in the engine compartment I could use when the car is turned on if I want to install LED fog lights on my AP2?
Old Nov 26, 2014 | 03:47 PM
Chuck S's Avatar
I've not seen what I'd consider fog lights for the AP2. Ebay LED sets for sure, but not real fog lights.
Are there any?
-- Chuck
Old Nov 27, 2014 | 06:06 AM
dakao's Avatar
Originally Posted by hecash
I used E to control a normally closed relay through which I ran the power which I tapped from C so that the DRL lights that are normally on go off when the lights are put on
I will check these out, thanks.
Are there any?
-- Chuck
Pro Import Tuners selling them for $100 a set.
I am using LED strips to make my own fog lights.
Old Nov 27, 2014 | 07:45 AM
S2Kennyy's Avatar
Guys, there called DLR's not fogs
DLR- Daylight running lights
Old Nov 27, 2014 | 10:45 AM
dakao's Avatar
I know S2000 has DRLs, but I am trying to install fog lights on my bumper. Thanks
Old Nov 27, 2014 | 05:31 PM
jetboater's Avatar
Didn't realize you had fog in Texas!
Make sure to use yellow LEDs if you want fog lights---white or bluish white light is useless In the fog.
The eBay ones are called fog lights by some folks but they're actually DRLs mounted where fog lights would typically be mounted.
Old Nov 27, 2014 | 05:39 PM
zeroptzero's Avatar
Red wire going to the spare slot in the underdash fuse box is the one you want to use. I put my lights on a switch so I can turn them off if I want.
Small rocker switch mounted in dash, optional
Old Nov 27, 2014 | 08:52 PM
dakao's Avatar
Oh yeah! Fog is bad in TX during winter..
Excellent! Thanks.
bewareofthepoop
Sep 17, 2013 09:59 AM
supwitu
South Florida
Nov 13, 2007 08:02 AM
