Sponsored by: CARiD
Installing koni yellows today.
Old Dec 12, 2008 | 10:43 AM
combats2000's Avatar
Default Installing koni yellows today.
On eibach springs!
For those who have it, or know about it, how did you set them up for street?
im thinking puting it on 3/4's all around
and lower perch. any other differences? other then .5 inch lower on lower perch
*************** the new koni yellow didnt come with a bushing(that goes between on upper strut.. they say you have to use stock, but its a lil to small, wont go over... do you have to drill?*********
Old Dec 12, 2008 | 12:22 PM
GPW AP2's Avatar
Originally Posted by combats2000,Dec 12 2008, 11:43 AM
1. im thinking puting it on 3/4's all around
2. and lower perch. any other differences? other then .5 inch lower on lower perch
-Marc
1. What?
2. The lower circlip holes are not the same front to back. One is higher than the other. I just don't remember which one is higher or lower.
By the way why did you get the Koni's? You just had a post about an isue with your springs right?
John
Old Dec 12, 2008 | 12:24 PM
spring issue was fixed. back settled nicely + had to retorque the lower control arm, while car was on the ground, it did the trick.
still a little staggered, but nothing like before
front 1.5 fingers .. back 2.5 fingers. before it was 3-3.5 fingers
PS. got the koni's to do a little better drop.. and IMO from all the reading i did, there better then oem for handeling. and adjustable .. i can stiffen/loosen the ride .. my choice
Old Dec 12, 2008 | 12:26 PM
GPW AP2's Avatar
So why did you buy the Koni's? Were you not happy with the springs?
John
Old Dec 12, 2008 | 12:33 PM
John
I wasnt thrilled about the drop..
.90 front .70 at 1st rear now .80
another .5 front and back.. plus a better shock... better handling
cant go wrong.
Old Dec 12, 2008 | 05:08 PM
cant go wrong.
nvm, did a search and found my answer..
everone is saying they like it adjusted at 3/4
how many turns is that?
Old Dec 14, 2008 | 09:53 AM
Integra21's Avatar
well there are 2 full turns of adjustability. so 3/4 would be a turn and a half.
im set at about 1.75 turns. They say its not good to go full stiff or full soft. (not being able to turn knob anymore.)
Old Dec 14, 2008 | 09:56 AM
chetly's Avatar
When I had the koni's with stock spring, I ran at full stiff in the front -1/8 turn and 3/4 stiff in the rear. Seemed to work better in an auto-x with those setting vs 2/4 still all the way around.
Old Dec 14, 2008 | 10:12 AM
mine seem to have 2.5 turns from full stiff to full soft
the rear driverside, is a pain !!! how do you guys do it, is there a easy way?
Old Feb 17, 2009 | 10:43 AM
dobiechris's Avatar
I have mine on the lower perch and with Eibach's. I think it is too low. I scrape the little plastic things under the front bumper when I take turns fast; might be due to the lower compression rate vs stock. I am thinking of going back to the higher perch, anyone know if this will fix the scraping problem? I have the settings at 3/4 all around also.
