Sponsored by: CARiD
Invidia 70mm Testpipe
Old Mar 17, 2015 | 12:29 AM
snmalone's Avatar
Default Invidia 70mm Testpipe
I have a 70mm Invidia Testpipe attached to my stock header and a Greddy SE Dual. I just can't get it right, the exhaust seems to blow between test pipe and header, i have the feeling the collector from the header is to small to fit the 70mm test pipe. i didnt have this issue with the 60mm testpipe i had before. anyone else who had this issue? The exhaust just sounds strange because it leaks. maybe it's better with the 70mm berk test pipe??
Old Mar 17, 2015 | 03:44 AM
Memo6453's Avatar
maybe doughnut is leaking?
Old Mar 17, 2015 | 04:14 AM
snmalone's Avatar
that's what i thought as well, but i bought a new doughnut gasket, still not better. It looks to me that somehow the flange of the invidia tp doesnt really fit?
Old Mar 17, 2015 | 07:06 AM
boosted180sx's Avatar
My invidia fits perfectly fine onto the stock header
Old Mar 17, 2015 | 08:33 AM
Reckon's Avatar
Mine fits fine as well. It could be a one off problem with a bad TP. Did you buy it new from Invidia?
Old Mar 17, 2015 | 04:27 PM
iDomN8U's Avatar
How compressed are the header springs? Postba picture if you can
Old Mar 18, 2015 | 02:34 AM
snmalone's Avatar
The nuts are as tight as possible and the springs are almost completely compressed. I bought the TP new from Invidia. I'll try to make a picture. Does anyone's car also sound very tinny and kind of like an old car with a broken exhaust? somehow it just doesn't sound right once the TP is attached... had a 60mm Tespipe before and it sounded way better and right in comparison..
Old Mar 18, 2015 | 02:53 AM
noodels's Avatar
Had to modify my bolts fitting a Berk HFC by grinding the flanges down flush on the area on the shank of the bolts,then found out the threaded area needed spacing out with washers to achieve more nip on the doughnut ring.
Old Mar 18, 2015 | 05:11 AM
iDomN8U's Avatar
you might need to do this:
https://www.s2ki.com/s2000/topic/108...n-warning-fix/
Old Mar 18, 2015 | 08:30 AM
snmalone's Avatar
This forum never lets one down! Thank you for those hints...that might be the solution! I will try to fill it up with washers and let you know if it worked. thanks a lot!
s2000maniac
Jul 25, 2011 05:03 PM
CaseyGW
Jan 2, 2010 11:02 AM
gusrock77
Jul 22, 2008 07:11 PM
pininfarina456
May 25, 2008 03:22 PM
el10034
Mar 23, 2007 08:00 AM
