Sponsored by: CARiD
Invidia TP with CELFIX (Restrict airflow) ?!?
Old Dec 8, 2009 | 11:35 AM
AngryTurtle's Avatar
Originally Posted by kaissi,Dec 8 2009, 08:15 AM
I use to have 60mm testpipe with no CELFIX, I fixed the issue by putting a spacer to the O2 sensor (non-fouler). Now I got the 70mm and I bought it with CELFIX, it turned out that the fix is embedded ?!? Isn't this restrict airflow? I mean the whole idea of the Invidia N1 exhaust is that it has less weight and minor curves for minimum air restriction?!?! Then why did they do a testpipe with CELFIX from inside?!?!?!
You could spit before you get in your car. That will make you lighter and you will gain the horsepower back you lost from the CEL fix.
Old Dec 8, 2009 | 12:10 PM
svencarlson07's Avatar
i have a 70mm invidia tp with the cel fix as well and it does not have that either just has the lil bung off the side
Old Dec 8, 2009 | 01:08 PM
kaissi's Avatar
Should that be funny ?!?!? I mean, even if it's negligible ?!?! what's the point of having it. An external built in non fouler or spacer is better than this, specially that if you read some posts claiming it still doesn't fix the CEL... designers worry about curves ..minor ones...for better air flow... so yes ...if you have the option to remove a block in the middle of the testpipe..why not..
Old Dec 8, 2009 | 01:14 PM
Hershey's Avatar
i got the same 70mm test pipe just like the one in the picture. it doesnt work at all. i have to use the nonfouler also. but it did dyno gain 5hp with a ebay header.
Old Dec 9, 2009 | 07:01 AM
rjohnstonstl's Avatar
I bought the 60mm Invidia pipe over the 70mm because I was concerned about the embedded fix in the 70mm pipe restricting flow. I put three of those HELP! anti-foulers on and I haven't had a CEL in three months of daily driving.
renegomez81
Apr 2, 2012 08:15 PM
tylek17
Feb 15, 2010 03:38 PM
mustangkiller01
Mar 4, 2008 06:29 PM
SH4DY
Feb 2, 2007 12:40 PM
Spec-D@Tin
Jan 11, 2007 08:11 PM
