J's Racing/Voltex 3D Wing Trunk Mount
What's up, S2Ki Family!
Does anyone know where I can acquire a trunk mount for a J's Racing wing? Picked up a 3D Type 1 wing from a fellow S2Ki member but the trunk mount wasn't included. If I can recall correctly, Voltex hardware should be compatible (correct me if I'm wrong ).
Does not necessarily have to be J's Racing or Voltex but as long as it is compatible . Any help is appreciated!
Thanks in advance, fellas!
Bringing back an old thread with a related question. I saw a few local selling J's 3D GT wings, but for a different car. One for an Civic EF and another for a RSX. Curious if all the wing have the same mounting point on the wing, but uses different trunk mount for different cars? In other words, if I get the J's 3D GT wing from the Civic EF, and buy the base mount for the S2K, will it work?
Also I know that the mount is a 4 hole mount, does it uses the same 2 hole from the OEM wing mount?
Thanks!
Thanks!
yes it will probably work. the wings are universal. as long as you get the s2k specific base mount you should be good
as for your second question this is personal preference i mean you can use the oem hole mount but in my opinion it looks better when the base is flush with the edge of the trunk
i guess it depends if you plan on putting a spoiler on in addition to the wing then you should mount it accordingly with the spoiler
I actually sell an improved version of these. The stock ones are known to cause trunk bending just from installation.
https://baero.tech/s2000shop/voltex-wing-baseplates
