Sponsored by: CARiD
J'S racing slave cylinder
Old Jan 7, 2010 | 05:58 PM
jonq67's Avatar
Default J'S racing slave cylinder
Anyone have experience with J'S Racing slave cylinder.
I need to replace the Slave cylinder in MY00 S2000.
My car has an aftermarket heavy duty clutch. This clutch was installed by the previous owner and he did not remember what the brand was. The clutch has a very stiff pedal.
Speed Alliance :: Honda :: 2000-2003 S2000 ::
J'S Racing S2000 Large Slave Cylinder for AP1 and AP2
J’s Racing has modified the stock slave cylinder and replaced it with a larger diameter piston which has 35 % more surface area. The large slave cylinder significantly reduces the pedal effort and is very beneficial when your car is equipped with a performance clutch with a high clamping rate. It will maintain the same strength and durability as a stock cylinder. Two copper washers are included.
SKU PO-S1-100
Price: $245.00
Old Jan 8, 2010 | 04:31 PM
jonq67's Avatar
Bump
Old Jan 9, 2010 | 07:39 AM
jonq67's Avatar
Anyone have any information on this?
Old Jan 12, 2010 | 08:45 AM
jonq67's Avatar
Ok how about J's racing in general. Any input as to the quality of there products?
Old Jan 12, 2010 | 08:51 AM
S2000 CR's Avatar
J's Racing makes great products, I have experience with there intake/ header/ exhaust, not sure about the slave cylinder though, try contacting some of the vendors on here and hearing there input?
Old Jan 12, 2010 | 09:50 AM
street_ruler's Avatar
you're going to need more pedal travel with this part. keep that in mind after you install you will need to adjust it a lot
Old Oct 20, 2013 | 09:55 AM
(-n0-)'s Avatar
I am considering this slave replacement with stock clutch for now. What kinds of adjustments would need to be made?
Old Oct 20, 2013 | 03:21 PM
Shaybird's Avatar
J's racing in general is amazing. Although I never had experience with the slave cylinder, I've purchased other products that are unbeatable in quality. They often set the benchmark for craftsmanship
Old Oct 20, 2013 | 05:16 PM
(-n0-)'s Avatar
Thanks for the response Shaybird. I agree their products are very high quality. I was wondering about the post before mine by Streetruler when he said:
Does anyone know what type of adjustments might need to be made?
Thanks!
Old Oct 21, 2013 | 04:40 PM
GoTuningUnlimited's Avatar
Former Sponsor
No adjustments required when installing this part. We've installed it on many S2000 and it's a direct swap to the OEM one. We keep these items in stock for when people swap out clutch master cylinders which typically go bad after a couple years.
