Sponsored by: CARiD
Jdp rear diffuser install tips/instructions
Old Apr 29, 2016 | 01:17 PM
jetguy's Avatar
Default Jdp rear diffuser install tips/instructions
Just received my beautiful JDP rear diffuser! No instructions were included. Can any help me with install instructions and tips you may have learned during your install?
Many thanks!
Old Apr 30, 2016 | 11:23 AM
Ragnarok043's Avatar
its been awhile since ive installed mine but its pretty straight forward. thoroughly clean your bumper then lay out some cardboard underneath so that you dont scratch your new carbon fiber diffuser. dry fit the diffuser making sure it sits flush against the bumper and mark a guideline with some blue painters tape along the edge where it meets the bumper, step back and make sure its aligned evenly. if it doesnt sit flush like mine did, carefully trim it with a dremel tool til it does. looks good? apply the supplied surface primer along edge where the double sided tape will meet the bumper. peel off a tiny corner(about an inch) of the double side tape backing(DO NOT PEEL OFF COMPLETELY)and hoist the diffuser up to the bumper using the guide line you did early with the blue painters tape. if you dont have a helping hand, use the blue painters tape to temporarily hold the diffuer up to the bumper. with the diffuser lined up with the bumper there should be enough of a gap to slowly pull the rest of the double side tape backing, as youre pulling the tape backing off firmly push the diffuser up against the bumper. as for the bottom pan the included hangers goes towards the front end and the rear end mounts to the stock bumper mounting point
Tougemon
Jun 19, 2016 03:07 PM
Vtec_Power
Oct 16, 2015 08:22 PM
lolS2K
Sep 13, 2015 06:02 PM
SilverStreak476
Jun 30, 2013 12:06 AM
jlovat12
Apr 28, 2012 02:11 PM
