Sponsored by: CARiD
Just installed TEIN S-Tech
Old Jul 24, 2009 | 06:55 AM
  #31
GPW AP2's Avatar
Originally Posted by bb_00,Jul 24 2009, 06:51 AM
Hey All. It's been almost a week since I lowered it. Now the springs seemed to have settled. Both the front and the back have 1-1/2 finger gaps and they seem to be even. I'm still not sure how some of you can have 1 finger gap on the front and 1.5-2 on the back.
If you did the preload procedure again, I bet the front would go down a little bit.
John
Old Jul 24, 2009 | 06:58 AM
  #32
aCab's Avatar
whenever checking ride height, park it on a completely level surface. I notice my car with espelirs sits differently at different angles, even on a very very slight grade. Guess its the nature of springs.
Old Jul 24, 2009 | 09:52 AM
  #33
mr.himself13's Avatar
Here are mine settled.
Old Jul 24, 2009 | 09:59 AM
  #34
bb_00's Avatar
John
John, I just spoke with my mechanic and he told me that you can only do preloading on true coilovers and not just springs swap.
aCab, thanks. I'll try to look again on a flat grade.
Mr.Himself13, great pix. Mine seems to look higher than yours. I am running stock wheels if that matters.
Here are some latest pix:
https://www.s2ki.com/forums/index.php?act=m...mage&img=643943
https://www.s2ki.com/forums/index.php?act=m...mage&img=643942
https://www.s2ki.com/forums/index.php?act=m...mage&img=643941
https://www.s2ki.com/forums/index.php?act=m...mage&img=643940
Old Jul 24, 2009 | 11:05 AM
  #35
GPW AP2's Avatar
Not true, most likely the terminology is being confused. He is most likely thinking about setting the spring preload on a coilover. We are talking about loosening the control arm bolts to be sure that the rubber bushing is clocked correctly. If they are twisted and not clocked correctly they can actually hold the car up at a higher level.
John
Old Jul 24, 2009 | 12:00 PM
  #36
Boofster's Avatar
John
Maybe we're using the wrong wording but it's the concept that matters.
Old Jul 24, 2009 | 12:03 PM
  #37
bb_00's Avatar
John
If that's the case, then I'm not sure.
I would hate to have it done again.
What's the cons for not preloading?
Old Jul 24, 2009 | 01:41 PM
  #38
MasterForce's Avatar
do you have to preload the springs?
Old Jul 24, 2009 | 01:50 PM
  #39
Rdizzle's Avatar
Preloading is compressing the springs in a coilover setup before installing it. This effectively increases the spring rate of the coilover since it is under load.
What the guys on this thread are mentioning is loading the suspension. Think of it like this, if your car is up on jack stands (or a lift), the suspension is in full droop. When you put it back on the ground, the suspension components are compressed (springs, shocks, bushings, etc).
If you tighten the suspension bolts without loading the suspension first, all your components will be tighted when they are in full droop (not how your car normally sits on the ground). When your car gets back on the ground, your suspension components will be in a high tension state and will cause increased stress on your suspension.
Old Jul 24, 2009 | 04:01 PM
  #40
bb_00's Avatar
Thanks for the great info, GPWAP2 and Rdizzle. I'll talk to my mechanic again tomorrow when I go see him.
Also, I started another thread in the Southern Ontario section.
https://www.s2ki.com/forums/index.php?showtopic=717249
There are some info as well for those interested.
