Keep stock air box?
Thanks, lots of info here. Ok can we separate the performance factors here? My understanding:
Airflow
Heat management
Resonance
So we are saying the oem system is good when it comes to airflow? Is the velocity stack key, because I have a k&n with no stack.
As far as heat management, the oem system maybe is good? I have a snorkel going over the radiator. Would that be better or worse than something like the aem v2 or similar design?
I know nothing about intake resonance tuning. Is this a key factor? Where can the power be gained?
So I have access to materials for very cheap. It won't cost me much to make and try new designs. Or should I just stay with the oem box?
Airflow
Heat management
Resonance
From what I can tell, intakes loosely group into two categories: Road and Race, with the former focused on the mid-range of each cam and the latter towards their top end. The confounding factor is exhaust resonance. Standing waves caused by reflections off the front face of the CAT create a dip in power around 4.5-5k RPM. It's first harmonic is 9k, coinciding with peak RPM, which is awkward for racing. As a result, systems either need to be optimised for midrange torque for daily driving like Mugen's or they are optimised for racing and peak around 4.5k and 9k, but require a decat/HFC/Gernpipe to avoid CAT reflections negating potential gains elsehwhere.
I believe that AEM style long tube intakes, generally peak around 4.5k and towards the top end ~9k, as a result of which you'll also need to replace your CAT for the full benefit. If you can play with its dimensions then you should be able to shorten it to drop its resonance to 3.5-4k for brisk daily driving.
Mugen's exhaust by contrast, is designed to resonate at 3.5k and 4k (and to a lesser extent about 5OO RPM either side) with a first harmonics at 7k and 8k i.e. it's tuned with a double-peak.
From what I can tell, many exhausts are symmetric with symmetrical backboxes equidistant from the center pipe. That means that they resonate in phase (and peak at the same RPM) leading to noisy exhausts. Most of the quieter twin exhausts by contrast have their centre pipe splitter mounted off-center leading to a more variable effect since the exhausts shift from constructive to destructive interference at different frequencies (reducing volume), while enabling them to tune for a double-peak resonance rather than a since one. (Double peaks are not necessarily broader overall, since a pair of high Q resonance peaks close together might be narrower than a single one with a lower Q.
I know you asked about intakes, but my point is that performance gains are maximised by a systemic approach. First decide where you want the power, resolve limiting factors such as CAT reflection resonance or aim for different RPM, fit an exhaust & manifold & tune your intake to match. Of course, you may get some gains with your intake at all RPM due to better flow (as with any straight through exhaust), but resonance is the more interesting question, so I thought I'd start there.
Here's dynos from a Mugen system, vs long tube & symmetric exhaust, and then vs a stock system:
https://www.s2ki.com/...st__p__23610353
zeroptzero,
I'll replace the air filter when the gauge reads 11" H2o. I have 82k miles on my air filter now and will replace it next Spring. I did a white glove test on my intake tube about 3 months ago and it was very clean(no dust or grime). When I do change out the air filter I'll take pic's of the old filter and the inside of the intake tube. The inside of the tube is not smooth the whole length, there is a ridge right in front of where I put the gauge. My S is a '06.
ROD
Originally Posted by Apex1.0' timestamp='1441727577' post='23740590
You have 8" off vacuum in the intake tube at idle? How much with zero air filter?
Does anyone know where I can get a reasonably priced air filter with a velocity stack?
zeroptzero,
ROD
Thanks Rod, that is cool information, do you use a foam type filter or cotton gauze type ?
I've recently gone to a cotton gauze filter on my Mugen intake, I was a big concerned about the filtering capabilities of cotton gauze filters when it comes to dust, so I put a K&N drycharger pre-filter wrap over the filter.
Originally Posted by rrounds' timestamp='1441685912' post='23740108
I put a gauge on the intake arm to see when to change the air filter and found that with a almost new air filter(8000 miles) it registered a vacuum of 8" H2o.
https://www.s2ki.com/s2000/topic/921...#entry21319421
ROD
ROD
One more thing, if you change the filter out often you will introduce a lot more dirt into the engine. Over the life of a filter, about 90% of the total dirt that will pass through the filter will pass in the first 10k miles.
ROD
Originally Posted by rrounds' timestamp='1441739431' post='23740898
[quote name='Apex1.0' timestamp='1441727577' post='23740590']
zeroptzero,
ROD
[/quote]
I'm running a stock air filter. If I tracked my S I would run the stock air box but change it just a bit. Like take out that plate in the middle of the air box and run a much larger filter, also block off the stock opening on the air box. I would get a spare hood and then make a functional hood scoop.
ROD
Originally Posted by zeroptzero' timestamp='1441741856' post='23740948
[quote name='rrounds' timestamp='1441739431' post='23740898']
zeroptzero,
ROD
[/quote]
ROD
[/quote]
The stock air filter is my preference. You have 82k on a stock air filter ?, hot damn !
Check out these three articles related to the stock air box and modifying it. There's stuff in there about resonance, intake air temps, etc.
http://www.motoiq.com/MagazineArticl...r-Testing.aspx
http://www.motoiq.com/MagazineArticl...ng-Faster.aspx
http://www.motoiq.com/MagazineArticl...take-Mods.aspx
Interesting. Tough to beat the stock box as delivered, hacks and snorkels may be questionable.
It seems most advocate the benefits of a long tube style CIA (like AEM), because of the trifecta of smoothing airflow, colder air source and also the benefit of resonance tuning. This can all be BS, but I am willing to try it.
I have the parts to make my own intake coming, will let you guys know what happens.
I believe an intake can make a difference. I like the idea of making a 3.5" intake tube.
I have an FIPK, took a run with my friend in his CR when we were both stock (exception being my intake). We were dead even until we hit vtec, after that I pulled on him.
Best of both worlds! K&n intake with oem box. (Lid is off to show how it looks inside). Foam strip is around the pipe where the box and pipe closes and i have a snorkel on now. Since people say the k&n intake gains power and a oem box w/ snorkel gains power too, then im sure i definitely gain some power! Ill post a pic of my current set up soon
