Kics spacer Question
It will work. I run Kics 10mm spacer in the front on AP2v1 rear wheel on the track, so you would have even less potential for clearance problems with a 15mm spacer. Just remember that the front center bore is 70mm and the rear is 64mm. From what I understand, Kics spacers come in 67mm center bore only, so you'll be fine running these in the rear, but you will have to get the center hole machined out if you want to run them in the front (as I did). The 10mm spacer will NOT work with AP2v1 front wheels because the recess is not deep enough, by about 2-3mm. It should work with a 15mm spacer, though. The steel that the Kics spacer is made of is not great quality steel, so it does make me worry a little. However, Evasive uses these spacers on their Time Attack Evo with no problems.
Originally Posted by myridechanelle,May 13 2009, 01:53 AM
does anyone know if you can replace a stud on the kics spacer? I sorta stripped one stud on the spacer...
