Sponsored by: CARiD
Koni yellows + ?
Old Feb 13, 2008 | 12:12 PM
jsys2k's Avatar
i saw a pic of the espelirs with konis on the lower perch and it was wayyy to low it was on a silver s2000. i want it like that but like a tad bit higher
Old Feb 13, 2008 | 01:47 PM
INTJ's Avatar
I'm back. Nope I haven't dynoed the shock. If I had a shock dyno it would get used 1x every 3-4 years. Where is your dyno that it is better?
There is a reason why the AX version of the YL is substantially stiffer than the stock spec one, and a custom build. The YL is a straight up consumer grade shock. Do a search and you will see a couple of complaints about the softness. Basically the rebound is OK, but there is hardly any bump control.
A stiffer shock really helps in the transitions, and makes no difference in stready state.
Old Feb 13, 2008 | 01:58 PM
iam7head's Avatar
Originally Posted by CrankDatVtec,Feb 11 2008, 10:30 AM
Skunk2 FTW...Best drop.
Espiler are great too.
are you the guy that cutted his own spring and argued for half a year that it doesn't compromise the ride and preformance?
Old Feb 13, 2008 | 02:08 PM
iDomN8U's Avatar
yeah, but he's alright... still wet behind the ears.
Old Feb 16, 2008 | 11:33 AM
jsys2k's Avatar
ok were getting off topic now
Old Feb 16, 2008 | 10:06 PM
squirrels2k's Avatar
koni yellows with eibach pro kit. got the shocks set to the lower perch. love the stance and the ride is good. i run full stiff in the front and half in the rear. handles better than stock. no rubbing at all with the stock ap2 rims and tires.
Old Feb 18, 2008 | 05:48 PM
jsys2k's Avatar
more pics of that setup please! i will runa search too
Old Feb 18, 2008 | 06:04 PM
bupton's Avatar
That's pretty low. Have any issues with scraping the front end coming out of driveways or speed bumps?
Old Feb 19, 2008 | 07:20 PM
jsys2k's Avatar
bump
Old Feb 20, 2008 | 06:18 PM
S-Turn AP1's Avatar
When you say lower perch you are refering to the second set of holes in the shock itself????
The eibach pro kit is 1 inch front and rear right????
