Sponsored by: CARiD
Kpro DIY!
Old Nov 12, 2010 | 05:32 AM
kevos2k's Avatar
Originally Posted by kaissi,Nov 12 2010, 08:18 AM
I wanted photos for PCV / drain plug washer.. it's not mentioned!!
the pcv just threads into the valve cover... it only fits in one place???
Old Nov 12, 2010 | 05:33 AM
kevos2k's Avatar
Originally Posted by kaissi,Nov 12 2010, 08:22 AM
Yesss...that's the one I was searching for.. I found it once long time ago and I lost it....
LOVE YOU
So it can be done with the engine in car..right..no need to take it off!!!
ya ive done 3-4 of these now... everything can be done in teh car... the cam gear sensor is a challenge to get to tho... i ended up modifying(shortening) an 8mm allen head socket to get it to work in the tight space....
Old Nov 12, 2010 | 05:40 AM
kaissi's Avatar
Originally Posted by spectacle,Nov 12 2010, 04:31 PM
Yes it can be done with the motor in the car. The crank pulley was the hardest part for me...couldn't get it off to save my life
Not sure why you would need pics of the PCV valve...it just screws in on the valve cover. You already have an AP2 correct? I believe they use the same one.
I have 2004 AP1!?!?!?!EDM
They come AP1 though everything in the car looks like AP2 .. headlights.. rims.. steering wheels... everything .. except the VIN is AP1... and the engine is F20C2... all EDM comes AP1 even 2009...
so I'm not sure yet.. I'm ordering a kpro soon.. I'm just preparing myself .. what I will be facing
Old Nov 12, 2010 | 05:45 AM
kaissi's Avatar
I have AEM V2 intake,
T1R 60R single tip Header back exhaust
AEM UEGO installed (AFR)
and I have an extra manifold that I want to port and polish..but didn't install yet. I also have a DC Header that I didn't install yet..
How much can I expect enhancement with these modes after installing kpro ?!
I tried AEM EMS 2 by the way.. but it didn't work on EDM version..
The readings on the laptop of all sensors were very fuzzy for some reason... I sold it.. and now planning for kpro.. I didn't want to go through changing all the sensors.. I have no other choice anymore.. flashpro does not work.. so kpro.... a friend of mine suggested haltech.. but since noone used it on this forum I figured it will be much helpful from you guys if I use kpro.. though haltech will require no change in any sensor..
Old Nov 12, 2010 | 05:49 AM
spectacle's Avatar
Call Hondata and talk to them to make sure everything is compatible. I'm sure it is, but you may want to check with them to be 100%
Old Nov 12, 2010 | 05:51 AM
kaissi's Avatar
You are absolutely right.. I thought after changing all these sensors.. there is no room for error .. but you know.. I should just in case..
Old Nov 12, 2010 | 03:48 PM
S2K-F8's Avatar
Yea Kevin, it was def. easier the 3rd time.
IIRC we didn't shorten an allen head socket, we bent an allen head wrench inward so it would clear the firewall.
Scott-
Old Nov 12, 2010 | 10:07 PM
buzz944's Avatar
will this help?
http://www.hondatuningmagazine.com/feature...tune/index.html
Old Nov 13, 2010 | 11:33 AM
kaissi's Avatar
That was my AEM problem by the way... check the coolant temp changing on throttle
[media]http://www.youtube.com/watch?v=1GchB7QSlLw [/media]&feature=email&email=comment_received
Old Nov 13, 2010 | 03:05 PM
J-GO's Avatar
By the time you screw around with making a allen that fits you can pull the exhaust cam out. Took me literally ten minutes to pull the cam out, change the sensor and put the cam back in. I spent way longer then 10 minutes trying to come up with something that fit. If i were to do it again i would just pull the cam out in the first place.
