Looking for suggestions on oil pressure temp gauge
I currently have dual pillar pod and have a AEM fail safe I plan on using in one spot.
I know innovate previously made a gauge that read both pressure and temp. I remember reading mixed reviews when previously reviewing the gauge. I was wondering if any other company made a gauge that read both oil pressure and temp? Or if anyone has any person experience with the innovate gauge.
If not I will just end up getting each gauge and figure out a way to mount the extra one. I appreciate any advice or information in advance.
I appreciate the suggestions I'm going to see if my tuner has any knowledge on the AEM serial gauge. The cars being tuned on infinity so I'm hoping that all of the horror stories I've ready about setting up the serial gauge won't be as bad.
The innovate mtx d kit looks like it would be pretty straight forward. If anything I may go this route because it looks like I could easily set everything up myself.
serial gauge won't work with the infinity. I am trying to do the same as you. I have a aem oil pressure gauge and I am going to see if I can feed a signal from that to the infinity. Another option is get a pressure sensor and try a bt innovations can bus gauge.
Thanks for the heads up ^
I think I'm going to end up getting the innovate dual gauge, it includes the sensors I believe and seems like it would be a pretty straight forward install.
I'm going to order it this week and I will make a updated post once I have it all installed.
I actually got mine from a place in florida. Dual digital and works great and simple.
http://www.veisystems.com/ws/
I am actually going to be removing mine. As they said above dont mount sensors on the plate. I think the vibration and temp kills it. I have been through 2 in 2 years. The temp sensor is fine there.
Only reason why i plan to remove is i feel i dont even use it. I look occasionally but rare. The system doesnt log temp or pressure which doesnt help to review issues.
http://www.spatechnique.com/store/itemList.cfm?catID=27
running a SPA dual gauge for oil temp and pressure. Expensive but really nice product. I am running pressure in the stock location (you need an adapter for this), and temp in the oil pan. My oil pan had the bung for the temp sender near the front of the pan on the passenger side and the included harness wasn't quite long enough to reach my a-pillar dual pod but extending it was easy, its just three wires.
