Sponsored by: CARiD
lower seats
Old Apr 13, 2012 | 10:33 PM
bigrobb6'5's Avatar
Default lower seats
hi im new to this site and im pretty sure that its been discussed about already but i wasnt able to find anything really useful the thing is that im a 6'5 tall guy and im searching for an ap2 s2k but the thing is that i dont know if i fit in one and a friend of mine is selling his 2006 ap2 for 10k and im thinking of buying it from him but i need to know what surefire way to lower the drivers seat at least 3" and/or if its possible to lower them even more any help would be greatly appreciated
Old Apr 14, 2012 | 06:01 AM
S~Factor's Avatar
I was able to lower my OEM seat 2". To lower it another inch would require you to cut a hole in the floor boards... or remove half the foam from the bottom cushion.
Old Apr 14, 2012 | 06:03 AM
AP1_Silverstone's Avatar
I say just take the rails off and weld the seat to the floor LOL... Ur tall man..
Old Apr 14, 2012 | 01:21 PM
WhiteAP1ftw's Avatar
Could you explain how, or point me to a thread where it is discussed?
To the TS, have you ever heard of punctuation? Jesus that hurt to read...
Old Apr 14, 2012 | 01:40 PM
JBAutosports's Avatar
Former Sponsor
I found this via a search...
Originally Posted by gche37
Hey Dwrights,
I have successfully lowered my drivers seat! I am 6'4" and had the same issue as yourself. It's not an easy project, so get ready for some drilling and cutting.
1) Remove seat from car by removing the four main seat bolts that hold the seat to the floor. Also unplug the seatbelt indicator that runs from the seat and under the carpet.
2) Turn seat upside down and remove all copper rings that attach the seat leather to the bottom of the seat pan. A couple of Needle nose pliers will do the trick.
3) Remove the 2 front side bolts and 2 rear bottom bolts that hold the seat pan to the seat rails. You will need a metric rachet set to do this.
4) Remove seat bottom and pull leather off from around the seat pan rim. After doing this, the cushion and leather will come right out. Don't go to the trouble of removing the leather from the seat cushion, because there is no need.
5) Using the proper size drill bit, drill a new hole an 1/8 of an inch above the 2 existing side front seat pan holes. Make sure you drill high enough to give room for another inside mounted nut. You will need to go pick you up a couple of nuts that will fit the existing bolt that the seat is connected to the seat rails with.
"JB Weld" these nuts to the inside of the seat pan just like the existing ones. This entire effort will lower the front portion of the seat about 1 1/2 inches.
6) To lower the rear part of the seat, you will need to do some hammering! I know this sounds crazy, but it works. Hammer the bottom of the seat pan and make sure that you keep it in proportion on each side. I actually hammered using a rubber headed hammer, by hitting directly on the two protruding bolts that come from the seat pan bottom. You can gain at least an inch to an inch and 1/2 by doing this.
7) Before putting the seat cushion back in, make sure that you haven't hammered the bolts out of wacked so that they won't match up to the seat rail brackets that the bolts should attach to. If you did do this , just hammer some more until you get it back in line.
8) (OPTIONAL) I cut and removed some of the seat cushion to get another half inch or so. Using a utility knife, you can cut into the cushion fairly easy. I then just started pinching pieces off little by little to make sure I didn't mess it up.
9) Put it all back together just like it was. Make sure that your nuts are lined up and very secure from using the "JB Weld" (No pun intended here Ha! ha!). You can find JB Weld at Wal-Mart.
It took me about 4 hours to complete. I know for a fact that after doing this, I lowered my seat 1 1/2 inches.
I can now see Red Lights with out ducking beneath my sunvisor all the time (When I'm the first car at the light that is). Good Luck! You can gain additional to this, by really cutting away a lot of the seat cushion. You may have to play around with it to get the results you like best. GOOD LUCK!!!
Greg
g_cherry@bellsouth.net
cadams05nfr's Avatar
I would like to know as well. Could help get my helmet below the roll hoops and also lower my center of gravity. Kind of a band aid till I can get some seats.
Old Apr 14, 2012 | 03:35 PM
Blue Gumby's Avatar
Recaro Pole Position with Buddy Club rails is the combo that i got. I have the Recaro pretty much touching the carpet. I'm 6'4" and even with a helmet with top up I'm OK.
Old Apr 14, 2012 | 03:56 PM
Do you, or anyone for that matter, know if there are rails taht can be used with the OEM seats to get lower? I would rather not pull my shit appart like in that DIY, and I like the factory seats...
Old Apr 14, 2012 | 04:38 PM
1nate7's Avatar
Backyard Special, but they only lower 20mm. Your best option is a side mount bucket seat, you simply can't go as low with the stock style bottom mount.
Old Apr 15, 2012 | 05:47 AM
Sideways's Avatar
I picked up some CF seats and made custom mounts that place the seat on the floor. It lowered my height by about 4 inches.
