Sponsored by: CARiD
Lowering question
Old Jan 5, 2008 | 04:46 PM
S2k1807's Avatar
Default Lowering question
Ok just bought a spa yellow 01 s2k about 3 months ago. So far all i got was a nice set of staggered driftz 505's on it. Ok i got 8 inch wheels in the back sittin on a 230/45 tire and i wanna lower it. Tire is a lil wide in the back if i hit a bump hard enough it will tap the fenders in the back a bit or if i take a corner faster than normal. Anyone have any ideas or do i need to go with a not so wide tire or a more low profile of one? Thanks
Old Jan 5, 2008 | 04:54 PM
SBlueS2k's Avatar
230/45 ?????? they don't make that tire size...
wheel size would help and offset.. maybe then i can help ???
Old Jan 5, 2008 | 05:01 PM
S2k1807's Avatar
have no idea what the offset is had them ordered at my friends shop they are 17x8, just went and checked its a 235/45r 17 94H
Old Jan 5, 2008 | 05:04 PM
2tirefire's Avatar
Sounds like you need to roll your fenders in the rear or possibly use a 225 series tire? You need to get us a bit more info to give you a educated answer.
Take the wheel off and see if there are any stickers or stamps on the wheel.
Old Jan 5, 2008 | 05:07 PM
S2k1807's Avatar
Kk thats what i thought i looked at it pretty close and felt how much i could roll on the fenders its going to be really close guess im gonna have to go with a 225
Old Jan 5, 2008 | 05:12 PM
iam7head's Avatar
first off here some facts:
245 is the OEM size for rear, 235 is not wide at all nor it's it's the proper size.
just to give you some scale, i am running a set of forge front with 8 inch and 9 inch rear without any fitment.rubbing issue.
my offset being 50ish in front and 63et in rear(have to check but they are not far off), which links me to think that your friend recommended you some wheel with poor offset fitment.
Old Jan 5, 2008 | 05:14 PM
iam7head's Avatar
part two:
sorry to say this but running a wrong offset wheel in s2k= bad for handling
some people get away with it by adding camber, shaving the quarter panel.
but since you can't even clear 235 tires, you might as well sell it and get something properly made for our car. it's a common mistake, i brought my car thinking i can use all the old school jdm 25et wheels on mine too.
you can check the ET by removing the wheel, it should be written/casted down some where, look for ET/OFFSET
Old Jan 5, 2008 | 05:15 PM
S2k1807's Avatar
Well dam this sucks, well my new wheels and tires look a ton wider than the ones that came on it factory and im glad to know that i just spent 1200 dollars on a waste of wheels
Old Jan 5, 2008 | 05:17 PM
iam7head's Avatar
the oem front is 205 and rear is 245(it will say 225 if you still have the oem s02, but they are underrated) for ap1(according to your sig.
Old Jan 5, 2008 | 05:20 PM
2tirefire's Avatar
Apparently you have the correct offsets for the AP1/2
In this case he has chosen a wheel that does not have the best offsets but easily workable with a smaller rear tire, which yes is not the correct size but will work in none the less.
a 225 will be fine in your case. Yes it may not be perfect in everyones mind but has been shown to work over and over in S2ki previous posts.
Here is something to consider. If you are only rubbing over bumps and certain cornering times you may wan to roll your fenders flush and get a UK spec alignment with -2 + of negative camber, this should solve your rubbing issues and not make you buy new tires.
Most people will say.........."buy a wheel with the correct offset", but in all actuality we work with what we have............My life's story........I am Asian
