Marriage?
I know the answer to the real "M" question...please!!
I am bringing together a Comptech CAI, ProFlow TB, Spoon Headgasket, & a Fujitsubo Legalis R Dual exhaust on my 2003 S.
Any issues I need to be aware?
Further mods that will be needed as a result?
Changes to the cars ECU???
THANKS!!
THANKS!!
I looked it up and it seems to be mostly a taper bore. You should be fine on the stock ECU and the parts you have listed should work pretty well together although I would recommend a different exhaust, something that flows a little better. The Fuji is a nice exhaust but doesn't produce but 1-2 HP. Get the T1R 70 V3 Evasive special or the ASM 70MM (both singles) if you want a quiet exhaust that produces power. You could also look into the new Berk dual exhaust but I don't know how loud it is.
High flow cat is cheap and effective as well.
Thanks.
second2none
Aug 25, 2009 11:44 AM
