mounting interior switch
I just installed led footwell lighting from js2k and was wondering if anyone has a creative suggestion in regards to mounting the on/off switch on the dashboard. Here's a pic of how it sits now..
Don't want to be drilling any new holes if I don't have to.
Is that a Photoshop, or just stuck there, or did someone actually drill a hole there? It you're stuck with a hole there are better looking toggle switches at the auto parts stores. If there's no hole I'd put it UNDER the dash with the toggle pointing down. No need to label it.
With some creative wiring you may be able to connect this to the dome lighting circuit. Foot wells would illuminate when the door is open for example. Or even a separate switch to do this. This is such a common "mod" I'd expect there are general solutions that work on several cars. There are some switches that will remain on for a period of time and switch off too. I've not looked at them in years, though
I'd like a LED to light temporarily near the ignition key where I tend to fumble or use the Braille method.
-- Chuck
-- Chuck
I mounted my LED DRL light switch on the lower dash just to the right of the radio controls. You can see it on the lower angled portion of the lower dash, just left of the steering wheel. It is a round rocker switch which has a small blue LED light diode that lights up when the switch is on. Drilling a small hole in that area is a piece of cake, and you have room to run the wiring behind it, it is also out of the way so you won't hit it getting in and out of the vehicle.
-- Chuck
-- Chuck
Love ur steering wheel bro. Ive been trying to get in touch with angelos to get one made but they appear to be extremely busy during the pre holiday season
I ended up getting a black plastic switch mounting bracket and "molding" my above switch into it. Looks a little more inconspicuous but still needs some touchups. May look into drilling a hole in the center console for it if I decide to keep it long term
GreenmanS2000
Dec 18, 2011 08:36 AM
