Sponsored by: CARiD
Need help with J's Engine Torque Damper
Old Dec 16, 2015 | 10:05 AM
radiantm3's Avatar
Default Need help with J's Engine Torque Damper
So I picked up a new J's strut tower bar and torque damper. I'm having a hard time figuring out how the damper connects to the hole in the tower bar. None of the bolts supplied will thread through the tower bar hole.
Here are the supplied bolts. The bracket and bolt that connect to the engine are already installed.
Also should note that the previous owner of this car had a spoon torque damper installed so that fuse box bracket below that hole has been removed. Not sure if that's the source of my problem or not. Any ideas from owners of this setup? Thanks.
Old Dec 16, 2015 | 10:52 AM
SeanGPW's Avatar
The part you are referring to in the first picture looks like a spacer for the side where you mount the ETD on the strut bar mounting bracket
When I was installing my J's damper I sent an email to J's USA to determine what size bolts should come I am uploading that PDF for you.
File Type: pdf
Old Dec 16, 2015 | 11:05 PM
radiantm3's Avatar
Thanks Jojo. That helped and I also realized that I was stupid and didn't see the vertical bracket at the bottom of the left side brace (after seeing your photo).
Old Dec 17, 2015 | 07:32 AM
SeanGPW's Avatar
Anytime! Your car looks great as well!
Kangs2k
Apr 21, 2009 08:21 AM
chrisyi1
24
Nov 7, 2007 06:54 PM
161MPHTOPSPDS2K
Oct 17, 2006 01:29 AM
Xplosiv
May 16, 2005 08:53 PM
