Need Help: Recaro Seat Rails
I bought a set of used seat rails but after mounting them to the seat, the mounting holes are about an inch wider than they should be. I double checked the part numbers and they are the correct ones.
I don't see any way to shift them over and it doesn't look like the side adapters are in the wrong location either (I tried). Any suggestions? https://cimg6.ibsrv.net/gimg/www.s2k...969d48aaf9.jpg https://cimg7.ibsrv.net/gimg/www.s2k...35cec8b8a1.jpg |
What's the part number on the rails and which seat are you trying to install? Do you have side profile pictures as well?
Originally Posted by Orjinal
(Post 24665579)
It's still unclear to me.......so are you trying to use a Recaro pole position with a recaro rail? if so, the PP is just too wide for a recaro rail, which is why people have been using PCI rails or Buddy Clubs for PP's. (Unless i missed something and Recaro started to make a rail that fits the width of the PP recently?)
Recaro Japan makes a rail for RS-G/TS-G/SP-G which is the part number you listed but they also make one for bottom mounts and another for SP-GN(Pole Position). All are specific to the seat they're made for and fit perfectly with that particular seat. You can't mix and match. It even says which seat(s) fit on the rail next to the part number.
(Post 24665938)
EDIT - i see so even though it says SPG on the seat it isn't actually a Recaro SPG according to the 070 part number in that pic. Wonderful. I have PCI seat rail right now and it sucks because i have to modify the seat belt receiver to mount it. I was hoping using Recaro rails would avoid that. https://cimg4.ibsrv.net/gimg/www.s2k...3350b239c3.jpg Seat bottom https://cimg2.ibsrv.net/gimg/www.s2k...a1cbfdbf13.jpg Seat rail |
Can you post more pictures of the seat mounts? Something doesn't look right
Originally Posted by jp182
(Post 24665953)
Originally Posted by arsenal
(Post 24666176)
Originally Posted by Chibo
(Post 24666236)
You need a receiver with an extension anyway, unless you plan on running the belt over the side of the seat which is terrible.
