New Rotor keep making weird noise when braking
Hey guys i just install some drill Password JDM Rotors prob a month ago, and most of the time when i let the car roll and slightly brake, the brake keeps make this grinding noise.... i don't really know why its doing that..... is it because of my pads? I'm using duraflex pads from auto zone or what? cuz on my stock rotor, everything seems fine when driving...... thanks for all the suggestions..... :)
Your rotors formed your pads into a "grove" if you know what im saying. this happens if you dont machine/ flip your rotors when you put on new pads. so your new rotors are perfectly "straight" while your pads arent. if you put a couple 100 miles on it, it should go away.
example "Pad" > > > > old rotor < < < < new rotor | | | | |
Is it a constant grind or does it only scrape your rotor in a certain spot when it rotates. 2 of mine scraped on a certain spot so i had to replace the wheel bearings.
Originally Posted by mrbond413
(Post 22096936)
Originally Posted by s2cho
(Post 22096630)
If it's more like a low pitched groan at very low speeds it's not abnormal.
slotted rotors seem to make more noise at certain times, are the password's slotted and drilled ?
Originally Posted by freetors
(Post 22097648)
Originally Posted by JFUSION
(Post 22097685)
Originally Posted by Kengthao91
(Post 22098233)
